Broke the rocker stand stud and T&D rocker shaft. #1887910
08/09/15 05:51 AM
08/09/15 05:51 AM
Aurora, Colorado
451Mopar Offline OP
451Mopar  Offline OP
Aurora, Colorado
I was using Doorman 3" long studs to hold the max wedge style rocker stands and the drivers side front stud broke after about 200 street miles? Do I have bad luck, or is there a problem running about 770+ open spring pressures on these Victor heads?
Re: Broke the rocker stand stud and T&D rocker shaft. [Re: 451Mopar] #1887920
08/09/15 09:07 AM
08/09/15 09:07 AM
MI, usa
dvw Online content
dvw  Online Content
MI, usa
Shaft broke because the stud broke. I'm not sure what grade a Dorman stud is but I don't use them for anything significant. You can buy individual studs directly from ARP. Tell them what size you want. My paired T&D's had 2 studs on each mounting bridge that I thought should be longer. Bought new ones from ARP, reasonable.
Doug
Re: Broke the rocker stand stud and T&D rocker shaft. [Re: dvw] #1887934
08/09/15 10:29 AM
08/09/15 10:29 AM
Arizona
Chris'sBarracuda Offline
Arizona
When I had my Stage 6's I had rocker issues until I added these
and changed the studs to 7/16" thumbs
http://www.timesert.com/html/bigsert.html
Chris. . wave
Re: Broke the rocker stand stud and T&D rocker shaft. [Re: 451Mopar] #1887953
08/09/15 11:58 AM
08/09/15 11:58 AM
Earth
Rob C Offline
Rob C  Offline
Earth
Scrap the Dorman. Cheap material for such a build.
Step up on quality bolts and there strength.
Re: Broke the rocker stand stud and T&D rocker shaft. [Re: dvw] #1887959
08/09/15 12:10 PM
08/09/15 12:10 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Doug
I agree the stud went first... not sure if it
was loose or just weak
wave
Re: Broke the rocker stand stud and T&D rocker shaft. [Re: 451Mopar] #1887987
08/09/15 12:49 PM
08/09/15 12:49 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Probably a reason Dorman is at the hardware store, and ARP is at the Speedshop.
...and I stand corrected smile
http://www.summitracing.com/parts/rnb-675-099
...but I'd probably been looking more this direction
http://www.summitracing.com/parts/arp-aj3-15l
Re: Broke the rocker stand stud and T&D rocker shaft. [Re: 451Mopar] #1888003
08/09/15 01:18 PM
08/09/15 01:18 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
to my knowledge all those hardware/auto store studs are grade 5.
Re: Broke the rocker stand stud and T&D rocker shaft. [Re: lewtot184] #1888020
08/09/15 01:45 PM
08/09/15 01:45 PM
MR_P_BODY Offline
MR_P_BODY  Offline
99% of the bolts in my car are grade 8 or above
except for some sheet metal screws
wave
Re: Broke the rocker stand stud and T&D rocker shaft. [Re: Chris'sBarracuda] #1888021
08/09/15 01:46 PM
08/09/15 01:46 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
[quote=Chris'sBarracuda]
Another stage 6... pulled the threads, bent broke the shaft. the heads weren't drilled deep enough for a longer bolt/ more thread engagement. Fixed it the same way as Chris.
Re: Broke the rocker stand stud and T&D rocker shaft. [Re: 451Mopar] #1888040
08/09/15 02:14 PM
08/09/15 02:14 PM
Aurora, CO
jbeintherockies Offline
Aurora, CO
Jim, you have ARP fasteners on everything else in/on that engine. Why did you go Doorman for the rocker shafts?
Re: Broke the rocker stand stud and T&D rocker shaft. [Re: 451Mopar] #1888048
08/09/15 02:24 PM
08/09/15 02:24 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
another prob Trendz is using those factory hold downs. They'll elongate the shafts over time and the rockers won't slide off the shafts.... found that out the hard way before going to aluminum hold downs with more surface area...
Re: Broke the rocker stand stud and T&D rocker shaft. [Re: J_BODY] #1888090
08/09/15 03:32 PM
08/09/15 03:32 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
With race cars after they hit a certain point you can spend a lot of money hopefully once the first time or do it on the cheap MANY times. The choice is yours.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Broke the rocker stand stud and T&D rocker shaft. [Re: pittsburghracer] #1888329
08/09/15 10:09 PM
08/09/15 10:09 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
I used studs with 120k psi rating.
Re: Broke the rocker stand stud and T&D rocker shaft. [Re: 451Mopar] #1888592
08/10/15 04:28 AM
08/10/15 04:28 AM
Aurora, Colorado
451Mopar Offline OP
451Mopar  Offline OP
Aurora, Colorado
When I ordered the studs from Summit, they did not have a 3" long ARP, and the Dorman studs I used are advertised as Grade 8? I even checked their catalog.
These were torqued to 35ft/lbs, do you think I need more pre-load?
ARP shows 45 ft/lbs for 3/8", 180,000 psi bolts?
I did order some ARP studs to replace these.
The heads have already been modified with 3/4" long timesert thread inserts, after milling the stock shafts off and using the Max wedge type rocker stands/hold downs. I'm not sure how I could goto 7/16" with the reduced diameter T&D shafts and have the rockers oil through the rocker shaft?
How much would it cost to have ARP make some custom studs???
FWIW, I ordered these: ARP-AJ3000-5B
Summit has the material listed wrong as 4037?
This is the description from ARP:
Stud, 8740 Chromoly, Black Oxide, 3/8-16 in. Base Thread, 3/8-24 in. Top Thread, 3.0 in. Length, Each
These ARP individual studs are made from 8740 chromoly steel with 190,000 psi tensile strength. They are precision centerless-ground and thread-rolled to Mil-S-8879 specs and have a black oxide finish. A nut and washer are sold separately.
Re: Broke the rocker stand stud and T&D rocker shaft. [Re: 451Mopar] #1888665
08/10/15 11:28 AM
08/10/15 11:28 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
yes, but note that nasty "pinch" on the Dorman stud where the threaded part meets the non threaded part.... I'm betting you won't see that on an ARP, and hopefully the ARP isn't threaded most of the length like the Dorman.
Re: Broke the rocker stand stud and T&D rocker shaft. [Re: 451Mopar] #1888684
08/10/15 12:06 PM
08/10/15 12:06 PM
Central California
MoParFish Offline
MoParFish  Offline
Central California
Hmmm, got me thinkin' as I run a couple of Dorman studs on my Victor/Sharp setup. I don't remember why but, like you, I'm sure it was because I couldn't find the right length ARP at the time. Dorman did list as grade 8. Are those stands positively located or just located by the studs? I remember your center rocker stand issues from a few years ago which prompted me to install inserts deeper in head before bolting them on. Thanks for posting back then. I hope your valve train issues go away soon...
Sworn Member Central Valley MoPar Drag Pack. You can reach me at (done-et-chasing@going-rounds.gone)... :-)
[img]https://s6.postimg.org/v3mbggksx/SAC16.jpg[/img]image hosting more than 5mb
Re: Broke the rocker stand stud and T&D rocker shaft. [Re: MoParFish] #1888955
08/10/15 06:00 PM
08/10/15 06:00 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
What I didn't like about the ARP 3" studs was that they are not threaded long enough on either end.
http://www.mcmaster.com/#standard-threaded-rods/=yfs8yu
If those don't work I'll use some grade 9 stuff:
http://www.mcmaster.com/#standard-cap-screws/=yfscrf
Sorry to see you are having problems again!
Re: Broke the rocker stand stud and T&D rocker shaft. [Re: 451Mopar] #1889095
08/10/15 10:13 PM
08/10/15 10:13 PM
glendora, ca.
Deepockets Offline
Deepockets  Offline
glendora, ca.
I ended up using the indy rocker studs that allowed me to have full thread engagement in the victor heads using the T&D rockers.
Re: Broke the rocker stand stud and T&D rocker shaft. [Re: 451Mopar] #1889304
08/11/15 03:50 AM
08/11/15 03:50 AM
Aurora, Colorado
451Mopar Offline OP
451Mopar  Offline OP
Aurora, Colorado
I got an E-mail from ARP and they said this part number:
PN: AJ3.050-1LB is an 8740 stud with .825" of 3/8-16 and .850" of 3/8-24. Torque would be 50 ft/lbs using the ARP Ultra Torque Lube.
Best regards,
Alan Nichols
Sales & Technical
Automotive Racing Products
1863 Eastman Ave.
Ventura, CA 93003
Toll Free: 800-826-3045
So, I ordered some of these too.
I think part of the problem was not enough pre-load on the studs with only 35 ft/lbs?
Re: Broke the rocker stand stud and T&D rocker shaft. [Re: 451Mopar] #1889474
08/11/15 01:39 PM
08/11/15 01:39 PM
USA
B3RE Offline
B3RE  Offline
USA
Can you be certain valvetrain instability didn't break the stud and the shaft?
Mike Beachel
I didn't write the rules of math nor create the laws of physics, I am just bound by them.
