2002 dodge neon NO spark?
#1887950
08/09/15 11:38 AM
08/09/15 11:38 AM
Posts: 1,468 N.Y.
sixpacksteve
N.Y.
just replaced the head on neon. standard procedure. went to start, no spark to coil. No codes either! checked all grounds! never messed with anything. Why no spark? checked all fuses.even replaced cam sensor! and the car ran prior to head removal.
Hell Hath No Fury Like Mine
Re: 2002 dodge neon NO spark?
[Re: sixpacksteve]
#1887951
08/09/15 11:54 AM
08/09/15 11:54 AM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Does the fuel pump do it's intial run when you turn the key to run (not start)?
If not look at the ASD relay, it supplies power to the ignition and fuel pump.
[Re: sixpacksteve]
#1887954
08/09/15 11:59 AM
08/09/15 11:59 AM
Posts: 1,468 N.Y.
sixpacksteve
N.Y.
yes it does, everything is normal
[Re: moretoys]
#1889371
08/11/15 11:04 AM
08/11/15 11:04 AM
Posts: 1,468 N.Y.
sixpacksteve
N.Y.
it Was the crank sensor! thanks
