Re: 4.7 engine problem
[Re: burdar]
#188756
01/09/09 08:29 PM
01/09/09 08:29 PM
Posts: 672 Keysville, VA
drag440
mopar addict
mopar addict
Keysville, VA
The 4.7 is an OHC engine so it shouldn't have rockers. I've had the covers of my 4.7 once to clean them up for paint but that's it. They are a pain to get off too. They aren't as bad as some people make them out to be but I had to remove the A/C compressor and move it out of the way. That made life a lot easer. Good luck finding the problem. Sorry I can't help much. I'll be watching to see how things go.
Yeah, I knew it was a OHC and I said rockers, but I recon they would be called followers on a OHC eng. or do they just run on top of the valves with buckets over the springs on 4.7's? Yall will have to bear with my country slang
[Re: Twostick]
#188768
01/11/09 03:55 PM
01/11/09 03:55 PM
Almost all leak at the thermostat--slow but sure.replace the stat and maybe the water neck to prevent the coolant loss My wifes 01 Grand Cherokee has been a PITA on trouble but she LOVES that thing! Heater door flaps is a $$ big one--window motors ( go aftermarket 1/2 price ) rear end whine--let it whine... oil sender bad shows NO oil pressure--thats good on Monday morning! New brakes all around and the pedal still goes way down oh..don't forget that power steering hose coupler that is a POS and cost $175 to fix but I have to put up with it so I can be a Mopar man--right?
[Re: moretoys]
#188769
01/12/09 06:46 PM
01/12/09 06:46 PM
drag440
mopar addict
mopar addict
Keysville, VA
If you have some noise also,I would pull the valve cover.Had one a couple weeks ago with a problem.the rocker had popped out of place.yes ohc, but it still has a rocker under the camshaft.compression will show ok,but that is because the valve isn't opening.Do a google on the problem.there are valve problems,also claims of carbon build up causing the problems(rockers popping out of place)pull the valve cover.
OK, a rocker arm was off. It took me about a hour to fix, but I don't want it to happen again. I sprayed a can of cleaner down the throttle body while it was running and put a can of cleaner in the tank then ran the crap out of it on the way home. What else should I do? I don't know where it got its slack to come out? The lifter or the valve had to stick. Should I put something in the oil also? Risolone maybe? The engine was very clean inside. I still don't see the anifreeze leak. I put it up on the rack and looked everywhere and it is very dry. The thermostat housing looks dry also, but I had to put another 1/2 gal. in today. The radiator is always full and the jug is always empty and I don't see a leak in the jug.
