Grand Caravan question #1887441
08/08/15 01:00 PM
08/08/15 01:00 PM
STL
cdstl Offline OP
cdstl  Offline OP
STL
I am looking at trading my '05 Grand Caravan for a '10 or '11 GC. My brother has a '13 and is having trouble with the ignition switch. It will not always start the vehicle or will sometimes start when the key is released. It is not a "normal" key but one of those plastic square-type keys.
Do you guys know of any items that may plague this generation of Grand Caravans that I should look for, or be aware of?
1972 Cuda 340 4 speed, 2001 Ram CTD 4x4 6 speed, 1970 Duster 408 4 speed, 1996 Ram 5.9 2x4 auto, 1965 Coronet 500
Re: Grand Caravan question [Re: cdstl] #1887449
08/08/15 01:22 PM
08/08/15 01:22 PM
New Jersey
P
Powerflow Offline
Powerflow  Offline
P
New Jersey
I also have an '05 GC and found this forum to be very helpful:
http://forum.chryslerminivan.net/forum.php
You may want to post over there and see what they have to say.
Re: Grand Caravan question [Re: cdstl] #1887455
08/08/15 01:30 PM
08/08/15 01:30 PM
Tallmadge, Ohio
P
Paul_B Offline
Paul_B  Offline
P
Tallmadge, Ohio
My wife has a 2011 Town and Country which is basically the same as the GC. The pentastar 3.6 v6 engine started in 2011 and I personally like this engine much better than the 3.8/4.0 engines in the 2010 and older models. The 3.6 engine has more power and better fuel economy. With my wife's van we typically see 26-28mpg on the highway for family trips.
Re: Grand Caravan question [Re: cdstl] #1887485
08/08/15 02:21 PM
08/08/15 02:21 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
My nephew has a 10.Has the same key.He beats it to death and no problems with the ignition.Rocky
Chrysler Firepower
Re: Grand Caravan question [Re: Paul_B] #1887489
08/08/15 02:25 PM
08/08/15 02:25 PM
STL
cdstl Offline OP
cdstl  Offline OP
STL
Good info, thanks. I think my brother is getting 25-26 mpg loaded down.
I will start focusing on the 2011s.
Re: Grand Caravan question [Re: cdstl] #1887516
08/08/15 03:23 PM
08/08/15 03:23 PM
ST clair shores MI
moretoys Offline
moretoys  Offline
ST clair shores MI
2011 is the first year for the 3.6 engine. depending when built, they have cylinder head problems,timing chain problems. If you look at a 2011 maybe all the bad ones have been repaired by now?This is not an engine for a back yard do it yourself kinda person can do.yes the 3.6 does get decent MPG's and has some getty up and go as well. I have a 2010 and it has the plastic key as well. I had a 1998 grand caravan and it got better fuel economy than this 2010 with a 3.8 and 6 speed transmission does.I have had this 2010 for about 6 months.2013 could be a push button ignition switch. key just has to be present in order to start. different system.
Re: Grand Caravan question [Re: cdstl] #1888316
08/09/15 09:56 PM
08/09/15 09:56 PM
va.
belvedere Offline
belvedere  Offline
va.
check for factory recalls they had problems with key switch
Re: Grand Caravan question [Re: cdstl] #1888360
08/09/15 10:31 PM
08/09/15 10:31 PM
Rio Raton
Lenguevo Offline
Wes Hutchinson says goodbye
Lenguevo  Offline
Rio Raton
My wife has a 2014, no ignition problems in the year we have had it. Much more powerful than the 2005 T&C 3.8 we traded in and also gets upwards of 25mpg on the freeway with a full load of people and luggage @ 80mph.
Also keep in mind these ignitions are tip start so you don't hold the key over in the start position after initial engagement.
Straight from 12th grade into junior college
Buddy, buddy, buddy, I passed my exam
Making me a law enforcement person
Got me a gun and a badge, I'm a man
Re: Grand Caravan question [Re: cdstl] #1888465
08/09/15 11:49 PM
08/09/15 11:49 PM
Lawton, MI
Headhunter22 Offline
Lawton, MI
Wife has a '10 GC, 4.0 with the entertainment system no navigation. 125k on the clock, I have put wheel bearings, multiple sets of brakes, changed the timing belt / water pump, fixed the entertainment system, changed the EGR due to stalling and a couple weeks ago had to take it to the dealer for replacement of a bulkhead connector that corroded causing the transmission to go into limp home mode. Ive also changed the serpentine belt a couple of times and the idler pulley once. I have performed all the maintenance myself and performed all the repairs other than the bulkhead connector. I didnt have the tools to diagnose the issue and felt I got off cheap as I was concerned it was a real issue with the transmission.
Van is paid off so we will keep it for a while yet but of all the work it was the entertainment system that really irked me. Dealer quoted $2200 to repair. It was an issue with a ribbon that connects to the fold down screens causing the entire system to fail. Did some research on a minivan forum and ended up buying a ribbon off ebay for $20 to repair the system. A little dicey in the middle dropping the entire overhead system but it was a two hour fix abd $20 in parts. Dealer wanted to change overall system, not hard just uncomfortable for me.
We have not had problems with the key but have a current recall on the switch that the dealer does not have parts to repair yet. When I was researching the egr / stalling issue I ran across some neutral safety switch info but no first hand information.
When I actually list this all out and consider we bought it new and havent beat it up I wonder about my sanity but the list on my '03 ram , 5.7 4x4 QC ram is equally as long.
