2012 Ram 1500 brakes went to floor #1885031
08/04/15 04:17 PM
08/04/15 04:17 PM
Middle TN
da50r Offline OP
da50r  Offline OP
Middle TN
Sitting still, pumping the brakes it's fine. Engine running and pumping, feels fine. Hit and hold, holds a firm pedal. Light touch and hold, it's firm. Pull it into drive, ease off so the truck will roll a foot, then reapply, goes right to the floor. Is this an ABS thing? Why is it fine and then roll it forward a touch and it's going to the floor? Fluid level a touch low but not out of the norm? Front brakes are worn but 3/16" left. They aren't on the backing plates. Will get them replaced this week. But why does the pedal dive when you go forward even a foot?
Re: 2012 Ram 1500 brakes went to floor [Re: da50r] #1887049
08/07/15 06:53 PM
08/07/15 06:53 PM
Middle TN
da50r Offline OP
da50r  Offline OP
Middle TN
No ideas huh?
Re: 2012 Ram 1500 brakes went to floor [Re: da50r] #1887055
08/07/15 07:09 PM
08/07/15 07:09 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Replace the brakes and get back to us.
Re: 2012 Ram 1500 brakes went to floor [Re: da50r] #1887194
08/07/15 10:54 PM
08/07/15 10:54 PM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
You have to start first with replacing the worn parts..3/16 is low..pistons are almost out of the caliper..if fronts are low then most likely the rears are low also. .did the dash brake light come on when the pedal went low?
Re: 2012 Ram 1500 brakes went to floor [Re: da50r] #1887760
08/08/15 11:05 PM
08/08/15 11:05 PM
Middle TN
da50r Offline OP
da50r  Offline OP
Middle TN
no dash lights came on.
Re: 2012 Ram 1500 brakes went to floor [Re: da50r] #1887841
08/09/15 12:57 AM
08/09/15 12:57 AM
Eugene, Oregon
Secret Chimp Offline
Eugene, Oregon
If there are no faults being reported, it sounds like a possible half-busted booster or check valve.
1967 Dodge Coronet Deluxe station wagon
1.03" T-bars, QA1 arms/rods, Cordoba/GM Metric/Volare brake & knuckle, XHDs, Hellwig rear sway, 318 Magnum w/ air gap, 727, 3.23s
Re: 2012 Ram 1500 brakes went to floor [Re: da50r] #1887982
08/09/15 12:47 PM
08/09/15 12:47 PM
ST clair shores MI
moretoys Offline
moretoys  Offline
ST clair shores MI
internal leak in the master cylinder.
Re: 2012 Ram 1500 brakes went to floor [Re: da50r] #1887992
08/09/15 12:56 PM
08/09/15 12:56 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
If a booster goes bad the pedal gets rock hard not to the floor.Its either because of low pads etc or a master going bad.
Rocky
Chrysler Firepower
