Re: Help me choose between these 2 cast harmonic balancers
[Re: sco440]
#1886509
08/06/15 09:17 PM
08/06/15 09:17 PM
Posts: 3,886 Lost and Spaced
bboogieart
Lost and Spaced
I too am confuse by the "bell housing" term. Do you maybe mean timing chain cover, or maybe the lower pulley? As scratching said; Harmonic balancers, go on the front of the crank. The bell housing refers to the transmission in the back of the motor. yes it matters witch one you use.
I have mechanical Aptitude. I can screw up anything.
[Re: sco440]
#1886558
08/06/15 09:59 PM
08/06/15 09:59 PM
Posts: 170 Western., NY
sco440
Western., NY
Sorry I meant lower pulley on the front of the harmonic balancer
'72 Road Runner '72 Dart Swinger 340 '12 Challenger R/T
[Re: sco440]
#1886818
08/07/15 11:16 AM
08/07/15 11:16 AM
sco440
Western., NY
Update, after checking the 440source site. I think the thinner one is a 71 and earlier "6pack dampener" because of the off set pulley bolt pattern. I can't use it as it's not cast. The thicker one that says cast crank has an symmetrical bolt pattern. Now I guess I need another symmetrical pulley because the one i have is not symmetrical. or can I just open up one of the holes slightly on the pulley to make it symmetrical?
