driveshaft length difference #188677
01/09/09 05:20 PM
01/09/09 05:20 PM
western Ky
CraigS Offline OP
CraigS  Offline OP
western Ky
Hey everyone,
I am putting a dana in place of the 8 3/4 in my barracuda.Will the driveshaft still work?
I am guessing it may neeed to be shortened,but any one with first hand knowledge?Thanks..........Craig
Re: driveshaft length difference [Re: CraigS] #188678
01/09/09 05:33 PM
01/09/09 05:33 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Driveshaft needs to be 1" shorter... Depending on the application parts manual shows a range of .8-1.2 shorter, most are right at 1"...
Re: driveshaft length difference [Re: 1_WILD_RT] #188679
01/09/09 06:16 PM
01/09/09 06:16 PM
BDW Offline
BDW  Offline
Is is this the same for a Challenger?
Re: driveshaft length difference [Re: CraigS] #188680
01/09/09 07:03 PM
01/09/09 07:03 PM
Not 1st hand knwowledge but since you are shortening one as opposed to finding one out of a dana equipped barracuda, I would suggest mocking it up & seeing how much exactly would need to be taken off that way with the potential stackup of tolerances it will right.
Re: driveshaft length difference [Re: BDW] #188681
01/09/09 07:30 PM
01/09/09 07:30 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
70 Challenger 727 or 4spd/8.75 45.60
70 Challenger 727 or 4spd/9.75 44.60
Re: driveshaft length difference [Re: RapidRobert] #188682
01/09/09 08:08 PM
01/09/09 08:08 PM
Hamilton, Ontario Canada
Magnum Offline
Magnum  Offline
I agree with mocking it up 100%. Not only for the reason Rapid suggested but also because the factory is usually too generous with yoke to seal clearance.
With the suspension fully loaded. Give yourself about 3/4" clearance from the seal to the yoke.
