cooling fans #188648
01/09/09 04:45 PM
01/09/09 04:45 PM
Boise Idaho
65coronet500 Offline OP
Boise Idaho
Hey guys
I am putting my 27 Dodge brothers coupe together and have been wondering what type of electric fans for engine cooling you guys use in your rods ??
It will have a 440 and a 4 speed trans no A/C etc.
I cannot put a clutch or fixed blade fan on it or I would (engine sits low in compartment but is the most practical place for it )
Please let me know what is working for you guys Thanks Matt
All steel 3800 lbs with me in it 65 Coronet 451 CID Indy 440-1 heads by Dwayne Porter racing heads .
..... 10.31 @ 129.4 mph 1.40 60 ft ALL MOTOR!!!!
Re: cooling fans [Re: 65coronet500] #188649
01/10/09 01:42 PM
01/10/09 01:42 PM
michigan
black64 Offline
black64  Offline
michigan
I used a griffin radiator with a cooling components 2700cfm fan w/shroud for my 392 hemi in a 40ford and it runs 180 degrees in traffic. check out www.customautoradiator.com they have all kinds for street rods.
Re: cooling fans [Re: black64] #188650
01/10/09 02:47 PM
01/10/09 02:47 PM
Boise Idaho
Boise Idaho
Huh
Is that a Spal Fan ??
If you are cooling a 392 with one I should be able to cool a 440 with one ??
Re: cooling fans [Re: 65coronet500] #188651
01/10/09 04:13 PM
01/10/09 04:13 PM
NEW JERSEY
dynamite Offline
dynamite  Offline
NEW JERSEY
It's not the fan it's the radiator..The fan in my truck only comes on in extreme conditions.. It comes on when the a/c is on but when it stopped working for a while I still drove at hiway speeds and ran cool..most any fan will do as long as you have the proper radiator
Re: cooling fans [Re: dynamite] #188652
01/10/09 10:52 PM
01/10/09 10:52 PM
Boise Idaho
Boise Idaho
Your Right !!
I know there is no replacement for a good radiator!
I was thinking that it cant hurt to have a fan that is overkill though
Re: cooling fans [Re: 65coronet500] #188653
01/12/09 01:47 PM
01/12/09 01:47 PM
michigan
black64 Offline
black64  Offline
michigan
Huh
Yeah the spal is a straight blade mine is S blade with the griffin rad W 1 1/2 inch tubes so it cools pretty good for an electric fan. The shroud is also a good thing to have with the fan.
