514 BBM 440-1 power numbers ?
#1886348
08/06/15 04:46 PM
08/06/15 04:46 PM
Posts: 77 British Columbia Canada
Challenger340
What do you guys typically see for Dyno numbers from your Indy 440-1 headed Wedge combinations ?
514 Cubic Inch * 4.440" Bore(mp Block) * 4.15" Stroke * 6.76" Rod * 13.5 C.R. * 440-1's (ported) * #8896 1050 cfm adapted down to the 4150 INDY Intake Manifold. * 278 @ .050 Roller .685" Lift.
We're pretty happy with 805 hp/7000 and 690 ft/lbs/5200 as FINAL NUMBERS with the Air Cleaner installed on 34* ?
We wanted to stay under .700" lift Cam as easier on parts/valvetrain/V-Springs over time(lotsa hits planned), and the Block wouldn't take a bigger Bore hence the goofy 4.440" bore size, and well.... all we had was a 4.15" crank, so....
Better to be a "has been" than a "never was".
Re: 514 BBM 440-1 power numbers ?
[Re: Challenger340]
#1886515
08/06/15 09:28 PM
08/06/15 09:28 PM
Posts: 10,384 Upstate NY
Bigcube
Upstate NY
Pretty good numbers! My motor is also 4.440" bore with Indy -1 heads but I have a 4.5" stroke. I went with 4.440" bore so if I ever needed to bore it I could still go to 4.5". I have dyno'd mine in 2 different configurations. The longer stroke typically adds some torque and lowers the peak HP over a smaller cube motor. HP seems to be related to heads and the bigger cube's just move the peak around. I made right around 806HP @ 6600 and 712 ft/lbs @ 5200 with at 11:1 compression and 93 pump gas mixed with a little 110 to play it safe. The cam in it is easy on valve train and under .700 lift. I pulled timing back a little and made a few pulls on straight 93 pump with an air cleaner and it made 784 HP @ 6400 and 697 ft/lbs @ 5500. A few years prior to that I've ran it with 15:1 compression, a little bigger cam and race fuel. It made 852 HP @ 7200 and 723 ft/lbs @ 5500 RPM. Compression drop and cam change lowered the peaks a few 100 RPM and lost about 50 HP and 20 ft/lbs. Hope this helps. What's it going it?
[Re: Challenger340]
#1886573
08/06/15 10:12 PM
08/06/15 10:12 PM
Posts: 10,021 Frostbitefalls MN (Rocky&Bullw...
gregsdart
528 Megablock, 4.15 stroke. I made 847 hp on Methanol, injected, 15/1 compression with .761 intake lift and 280 duration intake lobes. Advantages for mine were 4.500 bore,3x intake, injection, a bit more compression and more lift plus a couple of degrees more cam. Yours did very well! If your dyno sheets look like mine, the power (hp)is roughly the same from 6500 all the way to 7,000 rpm?
[Re: Challenger340]
#1886575
08/06/15 10:16 PM
08/06/15 10:16 PM
Posts: 43,317 Bend,OR USA
Cab_Burge
My 526 C.I. 440 block(4.375x4.375) made a little more than yours, it had a set of MCH CNC ported 440-1 with the 2.250 intake valves in them. It made 845 HP at 7000 RPM with a single 1050 Dominator on a Indy 440-3 intake and 2 inch Wilson reversion spacer, no air cleaner though. I didn't have a big enough set of dyno headers for that motors so it would start to miss a little at 5200 RPM all the way up to 7500 RPM One of the other local Mopar racers has a all out 571 C.I., 4.5 x 4.5 World block with a set of 440-1 that made more (875 HP I think ) HP than mine on another dyno at a lower elevation. IHTHs
[Re: Challenger340]
#1886725
08/07/15 12:56 AM
08/07/15 12:56 AM
Challenger340
So we're in the ballpark, THANKS fella's !
It's going in buddy's '67 Coronet, full-pop 3800 lb W/driver, Monoleaf/Caltrac setup, Dana 60, 4.56 cogs driving 32's. I gotta get out the sliderule and start doing some ET Calcs to figure out ET/rpm etc., etc. Been awhile, but I'll figure it out.
Any ideas what it should be looking for in ET/mph at that power to weight with a good 60 ft time ?
Thanks in advance
[Re: Challenger340]
#1886733
08/07/15 01:14 AM
08/07/15 01:14 AM
Posts: 1,267 North, Alabama
D-50
North, Alabama
The Wallace Racing calculator says 805 hp at 3800 lbs should be around 9.80 in the 1/4.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
