Stuck a/c clutch 440 #1886050
08/06/15 12:59 AM
08/06/15 12:59 AM
S.florida
Jupiter331 Offline OP
S.florida
I have a factory ac system 70 440. The compressor is fairly new but out of warranty. The clutch is stuck on all the time, even if I disconnect the power to the unit. My question is, is there any way to free it up.how is the clutch removed..... Never did an old Mopar. Any help appreciated
Re: Stuck a/c clutch 440 [Re: Jupiter331] #1886332
08/06/15 04:11 PM
08/06/15 04:11 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Remove the bolt from the front of the clutch (1/2" wrench) and then thread a 5/8"-11 bolt into the clutch hub. Tightening the 5/8" bolt will remove the clutch assembly....you must prevent the clutch plate from spinning when tightening the bolt.
Re: Stuck a/c clutch 440 [Re: Jupiter331] #1886595
08/06/15 10:32 PM
08/06/15 10:32 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I had some that just wiggle off after the nut/bolt is removed.IIRC there are still some in my other garage.rocky
Chrysler Firepower
