Re: ?? for guys with aftermarket steering wheels
[Re: Stanton]
#1885615
08/05/15 02:31 PM
08/05/15 02:31 PM
Posts: 5,812 ohio
ruderunner
ohio
Iirc the wire in the column is hot not ground. The steering shaft is ground. The roller is hot and insulated from the column, the switch compete the circuit to ground.
Angry white pureblood male
[Re: ruderunner]
#1885619
08/05/15 02:35 PM
08/05/15 02:35 PM
Posts: 1,386 Philadelphia PA
Pynzo
Drugs are bad
Drugs are bad
Philadelphia PA
I agree. I'm running a Grant Tuff Wheel and the adapter has a wire coming off the steering shaft adapter copper disc( it rides against the horn ground wheel that is part of the turn signal switch), runs through the wheel to horn button. It's plenty long enough.
[Re: Stanton]
#1885688
08/05/15 04:16 PM
08/05/15 04:16 PM
Pynzo
Drugs are bad
Drugs are bad
Philadelphia PA
The stock steering wheel has the copper disc built in. No extra ground wire passes from stock wheel to ground. And it's a ground for a relay- very little current passed through it.
[Re: Stanton]
#1885693
08/05/15 04:20 PM
08/05/15 04:20 PM
Posts: 8,871 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
Iirc the wire in the column is hot not ground I don't think so. If that were the case you'd be creating a "short" when you press the horn - this would blow a fuse. If its a "ground" then you would just be completing the circuit when you press the horn. Hot goes to the horn relay. I think !!
[Re: Stanton]
#1885717
08/05/15 04:51 PM
08/05/15 04:51 PM
Pynzo
Drugs are bad
Drugs are bad
Philadelphia PA
Horn Relay is wired: Violet(hot wire) to main power in- unfused Green w/ Red tracer- out to horns Black w/ White tracer- to Turn Signal Switch. And it is hot- ground wire to horn button. Push the horn button, the relay grounds and current flows from Violet to Green wire. Pull your steering wheel and check for yourself. Or use a test light anywhere along the Black wire.
[Re: Stanton]
#1885780
08/05/15 06:27 PM
08/05/15 06:27 PM
Posts: 21,071 Niles , Ohio
therocks
Niles , Ohio
Grant in my 65 and it looks just like the pic posted.My horn works fine.Rocky
Chrysler Firepower
[Re: Stanton]
#1886259
08/06/15 02:08 PM
08/06/15 02:08 PM
Stanton
Don't question me!
Don't question me!
Ontario, Canada
It is a circuit searching for ground. Yes, that's what I was saying. But some people figure that because it lights a bulb it's "hot".
[Re: Stanton]
#1889177
08/10/15 11:42 PM
08/10/15 11:42 PM
Pynzo
Drugs are bad
Drugs are bad
Philadelphia PA
It is a circuit searching for ground. Yes, that's what I was saying. But some people figure that because it lights a bulb it's "hot". Pardon Me, just got to this. That has got to be the stupidest statement I've ever seen posted on this site. You obviously have no idea what a circuit is. Where and who gave you your information about basic electrical principles?
