Re: 440 production date is this possiable?
[Re: V194]
#1884337
08/03/15 03:17 PM
08/03/15 03:17 PM
Posts: 3,519 Lansing, MI
70gtx440dana
Lansing, MI
440 in a 69 Charger has a date casting of 11.14.68 Is this correct for a 69? 1969 model year production started the first week of August 1968. An 11/68 cast date engine was likely used in a car built a month or so later. Check the VIN# stamped on the engine to confirm if it actually came in the car.
70 Road Runner 383-4 4 speed FJ5 & black guts 70 Charger R/T 440-4 4 speed FJ5 & white guts
[Re: V194]
#1884354
08/03/15 03:30 PM
08/03/15 03:30 PM
Posts: 8,948 Harlan, Iowa
69CoronetRT
Harlan, Iowa
Yes. My early Nov of '68 built '69 model has block with an Oct. '68 casting and assembly date.
Seeking:
1969 St. Louis plant VINs, SPD, and VONs. Over 2,000 thanks to you!
[Re: V194]
#1885338
08/05/15 12:30 AM
08/05/15 12:30 AM
Posts: 5,123 Warrenton, VA
RoadRunnerJD
Warrenton, VA
440 in a 69 Charger has a date casting of 11.14.68 Is this correct for a 69? It is a correct date for a 1969 motor. Are you trying to determine if it's the original engine or just trying to see if it's date correct for your car? The VIN will be on the passenger side bottom side of the block just above the oil pan. There is also some stampings on the front flat engine pad on the top driver's side of the block. It should read E440 HP with a couple of numbers that will be the month and day the engine was assembled. The E designates the year 1969. Let us know what you have?
