73 challenger high beam dash light #1885411
08/05/15 03:17 AM
08/05/15 03:17 AM
Monee IL
chicagotim2003 Offline OP
Monee IL
Trying to figure out how to get high beam indicator light to work. The red one on the speedo. Rallye gauges. Dash lights work. Foot switch works. Ideas? Thanks
Re: 73 challenger high beam dash light [Re: chicagotim2003] #1885486
08/05/15 10:36 AM
08/05/15 10:36 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
blown bulb?
trace the wires. check for voltage at the socket, check for solid ground at the socket. work backwards
**Photobucket sucks**
Re: 73 challenger high beam dash light [Re: chicagotim2003] #1885494
08/05/15 10:51 AM
08/05/15 10:51 AM
New Jersey, US of A
PlumCrazy73Dodge Offline
New Jersey, US of A
I would bet on a bad bulb if everything else is in working order.
73 plumcrazy challenger - 318/904, edelbrock performer 600cfm carb, performer intake and cam. Eddy Alum. Heads 3.91 locker, Doug's headers, accurate ltd. exhaust
73 Cuda - Triple Black 340 4 speed
MIKE
Re: 73 challenger high beam dash light [Re: PlumCrazy73Dodge] #1885582
08/05/15 01:41 PM
08/05/15 01:41 PM
been trying to figure out where the circuit to that bulb originates at & it'd have to be triggered from the high beam switch. www.mymopar.com might have it in their diagrams. I'd see if it gets fed from the dimmer switch or bulkhead or HL connectors (whichever one) & jump fire to that circuit then work downstream to find the open. You've checked the bulb itself. Kinda vague but that's my thoughts
Re: 73 challenger high beam dash light [Re: chicagotim2003] #1885616
08/05/15 02:33 PM
08/05/15 02:33 PM
Monee IL
Monee IL
It was the bulb. Duhh. I also replaced the turn signal lights. My hands are cramped and cut up !! Tight spot to work . Thanks guys.
