New Holley 625 Street Demon Problem. #1885244
08/04/15 10:48 PM
08/04/15 10:48 PM
Walton, Indiana
TimS Offline OP
TimS  Offline OP
Walton, Indiana
Thought I had my 71 Cuda all ready to drive to the Nationals but..... car all of a sudden won't idle when I tried to go to work in it this morning. I just put on a new Demon 625 a couple of months ago. Have driven around local probably 100 miles or so since. I've verified the obvious such as bad fuel. I did just fill the car up but it will not run any better out of a fresh can of gas.
Anybody run into this issue with their Demon? Getting ready to pull it off and put my old seepy thermoquad back on. Car ran great with that for years. Just couldn't stop the slight weeping from the upper gasket so I dropped some bucks for a new one. Any ideas would be greatly appreciated?
Thanks.
1968 Barracuda Fastback 318-2BBL 904 2.76 Frost Blue Survivor
1970 Roadrunner 440+6 BBL 727 AT 4.10 SG Dana Blue Fire Metallic
1971 Cuda 340-4 BBL 4spd 3.91 SG Curious Yellow
1972 Barracuda 318-2 BBL 904 AT 3.23 1 Legger Tor Red/White Vinyl Top
2007 Dodge Ram 1500 5.7 Hemi AT Patriot Blue
2011 Dodge Challenger RT 5.7 Hemi 6spd 392 SG Triple Black
2014 Dodge Charger RT Max AWD 5.7 Hemi AT 305 Billet Silver
Re: New Holley 625 Street Demon Problem. [Re: TimS] #1885250
08/04/15 11:04 PM
08/04/15 11:04 PM
Ottawa, ontario
dd340 Offline
dd340  Offline
Ottawa, ontario
Have you checked for simple things like vacuum leaks? Maybe it's not the carb at all.
Re: New Holley 625 Street Demon Problem. [Re: TimS] #1885252
08/04/15 11:06 PM
08/04/15 11:06 PM
WV
JohnH Offline
JohnH  Offline
WV
I bought one when I was restoring my 69,, It was junk from day one.. Get rid of it!!
Re: New Holley 625 Street Demon Problem. [Re: TimS] #1885260
08/04/15 11:13 PM
08/04/15 11:13 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
look for a piece of dirt in the idle jet.
Re: New Holley 625 Street Demon Problem. [Re: lewtot184] #1885263
08/04/15 11:19 PM
08/04/15 11:19 PM
Indiana
Y
YO7_A66 Offline
YO7_A66  Offline
Y
Indiana
Can you see the float levels on that carb? Can you verify that the needles/seats are not hung up with debris?
Re: New Holley 625 Street Demon Problem. [Re: TimS] #1885287
08/04/15 11:41 PM
08/04/15 11:41 PM
scratchnfotraction Offline
I remember someone here posting they do not like the 10%ethenol gas, eat the accel pump transfer tube up and they sent it back.
might have a look at that.
Re: New Holley 625 Street Demon Problem. [Re: dd340] #1885304
08/05/15 12:00 AM
08/05/15 12:00 AM
Walton, Indiana
TimS Offline OP
TimS  Offline OP
Walton, Indiana
No vacuum leaks. I would bet my Thermoquad works just fine when I put it on.
Re: New Holley 625 Street Demon Problem. [Re: lewtot184] #1885312
08/05/15 12:04 AM
08/05/15 12:04 AM
Walton, Indiana
TimS Offline OP
TimS  Offline OP
Walton, Indiana
When I installed this carb I put on new lines and a new filter. I also went the extra mile to cut my old filter up just to make sure I didn't have any rust particles coming from the gas tank. The old filter was pretty clean and no rusty particles. This Demon just appears to have bitten the dust pretty quickly.
Re: New Holley 625 Street Demon Problem. [Re: TimS] #1885339
08/05/15 12:30 AM
08/05/15 12:30 AM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
I have a couple 71 t-quads but no plastic bowls laying around. Try sanding the top of the bowl on a sheet of 220 grit sand paper to get it flat. The paper should obviously be on a flat surface.
Re: New Holley 625 Street Demon Problem. [Re: ademon] #1885356
08/05/15 12:51 AM
08/05/15 12:51 AM
get a can of brake kleen with a thin red straw & shoot a 3 second blast into each idle screw mixture port. first count the # of turns to lightly seated before you remove em so you can easily return the screws to their original position(s). then get a high flow 10 micron filter in line right before the carb inlet to ward off a repeat
Re: New Holley 625 Street Demon Problem. [Re: RapidRobert] #1885449
08/05/15 08:43 AM
08/05/15 08:43 AM
Walton, Indiana
TimS Offline OP
TimS  Offline OP
Walton, Indiana
I'll give that a shot before I pull that Demon off. I did just fill the tank up to get ready for the Nationals. Maybe I rustled up some junk in the tank or pumped some in from the station and it got past the filter.
Re: New Holley 625 Street Demon Problem. [Re: TimS] #1885588
08/05/15 01:47 PM
08/05/15 01:47 PM
the idle circuits have the smallest passages in the whole carb & it only takes one minute piece of debris in the wrong place to make it act up & speaking of the gas stns I've seen (& am amazed) at the amount of crap that gets past their "filters". Holler how things turn out
Re: New Holley 625 Street Demon Problem. [Re: RapidRobert] #1885944
08/05/15 10:36 PM
08/05/15 10:36 PM
Walton, Indiana
TimS Offline OP
TimS  Offline OP
Walton, Indiana
Well the Cuda is now running good. Why???? Not exactly sure. After work I bought another fuel filter that was 20 micron. I removed my old filter and cut that in half. It showed no signs of any issues. No dirt nothing. Looked new. I went ahead and installed my new filter and tried cranking the car. At initial trials without starting it backfired thru the carb once and rammed the horn plate closed on the Demon. I opened that back up and with a few cranks started the car. Let it warm and reset the air fuel mixture screws. It now runs great.
I would like to think that it just had some dirt in the carb, from were I don't know, and running the carb dry of fuel then repriming freed the dirt plug. or....... I have a minor vacuum leak and it is now sealed, for now. I did tighten the carb mounting bolts a bit last night but saw no change at that time. Tightening when the car was at temp.
Drove the car for an hour or so. Runs like it should now.
Re: New Holley 625 Street Demon Problem. [Re: TimS] #1886048
08/06/15 12:57 AM
08/06/15 12:57 AM
Zombieland
Car Nut Offline
Car Nut  Offline
Zombieland
Awesome news!
Re: New Holley 625 Street Demon Problem. [Re: TimS] #1886773
08/07/15 02:50 AM
08/07/15 02:50 AM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
I'll bet the lean backfire did it. Happy motoring!
Re: New Holley 625 Street Demon Problem. [Re: Jeremiah] #1886784
08/07/15 05:50 AM
08/07/15 05:50 AM
Walton, Indiana
TimS Offline OP
TimS  Offline OP
Walton, Indiana
Looks like. I ended up putting my old Thermoquad on there anyhow to play around with. I'm gonna try to get that weeping at the upper seal issue fixed. I really like the old carb better than this Demon anyways. I wonder if I have the float settings a bit too high on this Thermoquad?
