Progress on a Gen-2 HEMI #1885220
08/04/15 10:00 PM
08/04/15 10:00 PM
Sonora CA
Mopar_Rich Offline OP
Sonora CA
Slow progress is still better than no progress. I have to admit, I like the way it looks and Hogan's manifold, with billet runners is Jewelry. Can't wait to get it on the dyno and do some tuning!
Re: Progress on a Gen-2 HEMI [Re: Mopar_Rich] #1885234
08/04/15 10:27 PM
08/04/15 10:27 PM
Menomonee Falls
DemonDust Offline
DemonDust  Offline
Menomonee Falls
Wow!!! drool
That is the true def of engine porn..
SDG Motorsports
Hellcat Demon and Redeye Supercharger CNC Porting
https://www.sdgmotorsports.com/
Re: Progress on a Gen-2 HEMI [Re: DemonDust] #1885269
08/04/15 11:28 PM
08/04/15 11:28 PM
Tampa
DusterDave Offline
DusterDave  Offline
Tampa
Nice grocery getter motor. devil
Are you going with a pair of Holley Dominator throttle bodies?
Gone to the dark side with an LS3 powered '57 Chevy 210
Re: Progress on a Gen-2 HEMI [Re: Mopar_Rich] #1885423
08/05/15 04:31 AM
08/05/15 04:31 AM
Deep DEEP SOUTH
LAD 524 Offline
LAD 524  Offline
Deep DEEP SOUTH
WOW looks awesome Rich - that intake is super nice !!
What will the rest of the combo be?
Re: Progress on a Gen-2 HEMI [Re: LAD 524] #1885509
08/05/15 11:42 AM
08/05/15 11:42 AM
Sonora CA
Sonora CA
Typical stuff - not! First time I've machining the front cap/saddle and crank counterweight for a roller Torrington thrust bearing. Customer never wanted a thrust problem. Good parts: KB block (4.5) with roller cam bearings, Crower 4.625 crank/rods/Enduramax bushed lifters, CP pistons. Custom Comp cam that I designed with 18726543 firing order (LS core), Stage-V stainless rockers and Jesel drive. The Stage-V Millennium heads were done by Tim at FHO and flow well over 500 CFM. Obviously a super pretty Hogan manifold. Everything is O-ringed so no gaskets. It should produce enough to get to the grocery store, which is 1/4 mile away.
This engine is basically a slightly smaller version of engine combo 6 in my HEMI book, built for bracket racing longevity with less RPM, less compression, and a milder cam.
Re: Progress on a Gen-2 HEMI [Re: Mopar_Rich] #1886243
08/06/15 01:33 PM
08/06/15 01:33 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
What did they charge you for that intake?
2011 Drag Pak Challenger
Re: Progress on a Gen-2 HEMI [Re: Mopar_Rich] #1886247
08/06/15 01:42 PM
08/06/15 01:42 PM
Sonora CA
Sonora CA
What do you mean?
Re: Progress on a Gen-2 HEMI [Re: Mopar_Rich] #1886255
08/06/15 02:00 PM
08/06/15 02:00 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
Originally Posted By Mopar_Rich
What do you mean?
How much did the Hogan intake cost?
Re: Progress on a Gen-2 HEMI [Re: Mopar_Rich] #1886372
08/06/15 05:48 PM
08/06/15 05:48 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
You almost don't want to put oil in these works of art.
Sheldon
Sheldon
Re: Progress on a Gen-2 HEMI [Re: rickseeman] #1886534
08/06/15 09:41 PM
08/06/15 09:41 PM
Sonora CA
Sonora CA
What do you mean?
Sorry. A lot, but the customer paid in advance. I don't have the total. All I did was make sure the ports would match.
Re: Progress on a Gen-2 HEMI [Re: Mopar_Rich] #1910833
09/11/15 11:47 PM
09/11/15 11:47 PM
Sonora CA
Sonora CA
It's ready for the dyno.
Re: Progress on a Gen-2 HEMI [Re: Mopar_Rich] #1910888
09/12/15 12:58 AM
09/12/15 12:58 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Sure is purty!!
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Progress on a Gen-2 HEMI [Re: Mopar_Rich] #1911052
09/12/15 12:37 PM
09/12/15 12:37 PM
Deep DEEP SOUTH
LAD 524 Offline
LAD 524  Offline
Deep DEEP SOUTH
Killer Rich !!
Would love to know the spex and let us know how the dyno session goes !!
Re: Progress on a Gen-2 HEMI [Re: Mopar_Rich] #1911443
09/13/15 01:52 AM
09/13/15 01:52 AM
Sonora CA
Sonora CA
588, Stage V millennium heads ported by FHO, all Crower internals, roller bearing cam, KB block, cam is my design (LS core, 18726543), Hogan intake, relatively low compression (13+). Dyno in two weeks.
Re: Progress on a Gen-2 HEMI [Re: Mopar_Rich] #1917872
09/23/15 02:31 AM
09/23/15 02:31 AM
Sonora CA
Sonora CA
Even though the header ports didn't match the heads, and no vacuum pump and only 13.6 CR, it still made 1100 HP. It'll be a good bracket motor.
https://www.youtube.com/watch?v=Skeg3KK2uaM&feature=youtu.be
Re: Progress on a Gen-2 HEMI [Re: Mopar_Rich] #1917886
09/23/15 03:39 AM
09/23/15 03:39 AM
California
mickm Offline
mickm  Offline
California
rich, do you have any more pictures of the internals? would love to see as many pics as you care to post!
Re: Progress on a Gen-2 HEMI [Re: Mopar_Rich] #1917887
09/23/15 03:41 AM
09/23/15 03:41 AM
Sonora CA
Sonora CA
Anything specific? I have over 100 photos showing the progress.
Re: Progress on a Gen-2 HEMI [Re: Mopar_Rich] #1918020
09/23/15 01:03 PM
09/23/15 01:03 PM
California
mickm Offline
mickm  Offline
California
no, nothing specific. just think of it as an extension to your book! whatever you have time for. it's just a great learning experience to see what goes into an engine like this.
Re: Progress on a Gen-2 HEMI [Re: Mopar_Rich] #1918095
09/23/15 02:55 PM
09/23/15 02:55 PM
Sonora CA
Sonora CA
I think a good "white Paper" would be to discuss what I had to do differently to get around problems. Such as the special oiling system of a KB block usually feeds the lifter galleys (extra cost gun drilling) from a groove cut around the #5 cam bearing, but if you increase the cam bearings to 55 MM roller bearings you loose the oil feed channel. Then what do you do? Maybe I'll write an article about surprises of building a big block Mopar engine with aftermarket parts.
Re: Progress on a Gen-2 HEMI [Re: Mopar_Rich] #1918119
09/23/15 03:29 PM
09/23/15 03:29 PM
Skypower Offline
Skypower  Offline
I would be very interested in this as I am thinking of building another Hemi for my car, more along these lines only setup for turbo's. Great job with this build.
