Re: Lowering kit showed up any tips
[Re: 79machocharger]
#1885066
08/04/15 05:15 PM
08/04/15 05:15 PM
Posts: 12,422 Kalispell Mt.
HotRodDave
Kalispell Mt.
In my opinion a truck is useless as a truck once lowered. I have bought a few and hated it and either sold them or put them back to stock. My 99 RT dak is next on the list to go back stock, it has shorter coils on the front and beltech spring mounts on the rear.
#1885158
08/04/15 08:15 PM
08/04/15 08:15 PM
HotRodDave
Kalispell Mt.
When you lower it you move the axle closer to the bump stops that means less weight is needed to bottom them out so you should not tow/haul as much period.
[Re: HotRodDave]
#1885370
08/05/15 01:29 AM
08/05/15 01:29 AM
Posts: 774 Midland,Tx
wyldebill
Midland,Tx
I've towed all over the country with lowered trucks, so I call bs. Just my sorry to the op for going off topic
[Re: wyldebill]
#1885469
08/05/15 09:40 AM
08/05/15 09:40 AM
Posts: 5,443 ME
79machocharger
ME
The kit also provided lower bump stops as we'll. my dakota rt was done on the cheap prior to me buying it and I can see what your talking about. But with a quality kit and the correct parts as in shocks, spindles verses lowered springs and shorter bumps tops I'm thinking it will be fine.
[Re: Jwilli500]
#1886189
08/06/15 11:54 AM
08/06/15 11:54 AM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
If you're still using the same spring rate, towing shouldn't be affected. Unless you plan on exceeding the tow limits. A properly landed trailer, at or below the max rating of the truck, shouldn't come anywhere near bottoming out the suspension. Now, if you want to exceed the limits set by the manufacturer, then yes, you will bottom out on a lowered truck.
Yes the lawyers will tell you to never do that, but the factory ratings are always on the conservative side. Put 1000 lbs or 1/2 ton of cargo in the bed of a half ton truck, and you'll notice that the suspension isn't that compressed. I've hauled 1400 lbs of stone in the bed of a v6 Dakota before and wasn't bottomed out--but I only drove 5 miles like that, and it was through town at speeds of 35 mph or less.
I've seen lowered trucks using an auxiliary airbag system to help lift the back end up when towing heavy.
**Photobucket sucks**
#1886947
08/07/15 03:51 PM
08/07/15 03:51 PM
Posts: 5,784 Corpus Christi, TX
shanker
Corpus Christi, TX
most people who exceed the factory load capacity of trucks ALWAYS overlook the brakes....If you're going to tow, make sure and upgrade the binders
The Federal Government has not yet learned that you cannot legislate morality
1970 Coronet R/T FF4/FF8/V85/V1G 440/Auto/3.23
1970 Coronet R/T FK5/FK5/V8W/V1W 440/Auto/3.55
1970 Super Bee TX9/TX9/V8W/N96 383/Auto/3.91
1975 Duster 360 VS29L5 Daily Driver
