Re: E-brake stuck in place, need help
[Re: nomore65BelvJim]
#1884949
08/04/15 01:48 PM
08/04/15 01:48 PM
RapidRobert
What they said, confirm that the cable ain't taut (the mini ball at the end of the inner cable at the end of the sheath, that the binding is in the sheath or inside the drum) rather than the adjuster or ebrake lever (I'm sure you've released the ebrake lever up front). if still tight, the nut on the adjuster where the cables T under the middle of the car tends to be stuck from road debris marring the threads on the adjuster & if so remove the nut with a nut cracker rather than risk breaking the adjuster threaded length. then, worse case, drill out the brake nails on the back side (2) so you can pull the whole schebang forward a bit to get in there. EDIT I read your last post, you could cut the sheath right at the drum hole but those are hard to come by & I'd first drill the nails tho the sheaths might need replacing anyhow. If you get em out WO cutting them off, soak em in your solvent tank for several days & see if it frees up, good chance it will. MORE EDIT with the drum off use a small hose clamp to compress the tines on the inside of the b plate that lock the sheath in place, compress it enough to collapse the tines so you can pull the sheath out the back side, get the tines started thru the b plate then loosen the clamp
