Speedo gear needed
#188435
01/09/09 12:19 PM
01/09/09 12:19 PM
Posts: 9,982 Ansonia, CT
CJK440
Ansonia, CT
I have a 27" tall tire and 3.73 gears. What speedo gear should I use. The archives show 3.55 and 3.91 only of course.
2017 Contusion Blue Challenger T/A 392 M6 "BLKNBLU"
Re: Speedo gear needed
[Re: CJK440]
#188436
01/09/09 12:25 PM
01/09/09 12:25 PM
RapidRobert
You might put a piece of flat stock on top of one of your rear tires & measure the EXACT distance to ground. Tire mfr listed heights are usually not dead on accurate & this could tip you one way or the other on which pinion gear to select.
[Re: 446acuda]
#188438
01/09/09 02:25 PM
01/09/09 02:25 PM
Posts: 6,095 Valencia, España
NachoRT74
Valencia, España
simply 36 tooth... no more no less
[Re: NachoRT74]
#188439
01/09/09 02:33 PM
01/09/09 02:33 PM
CJK440
Ansonia, CT
Tire is actually supposed to be 26.8. Its a G70-14.
[Re: John_Kunkel]
#188441
01/10/09 06:08 PM
01/10/09 06:08 PM
RapidRobert
If the circumference dimention makes a more accurate read for this then I will start doing that & not recommending checking the height. I did use the piece of stock to get the height on my 65 dart to select the pinion gear & it's dead on but yeah the stackup of tolerances as in the tire dimention may have just worked out in my favor in this case.
