3-step gone bad? #1882837
08/01/15 01:25 PM
08/01/15 01:25 PM
off the grid
340B5 Offline OP
340B5  Offline OP
off the grid
I was searching for a fuel or ignition problem and found that if I disconnect the 3-step and plug a chip directly in the ignition box everything seems to straighten out. Anyone else had this happen?
Yeah, it's got a smallblock.
Re: 3-step gone bad? [Re: 340B5] #1883015
08/01/15 06:36 PM
08/01/15 06:36 PM
I've had problems with loose connections on my MSD 3 step runaway I'm still trouble shooting it, so maybe it is several things, not just one confused My message is , yes there are problems with every part made out there, under the correct conditions shruggy
Re: 3-step gone bad? [Re: 340B5] #1883119
08/01/15 10:12 PM
08/01/15 10:12 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
Mine got water in it a couple times and would activate the burnout limiter. Worked normally once it dried out.
But yes, a 3 step can cause issues.
