Is there.... #188277
01/09/09 06:07 AM
01/09/09 06:07 AM
Mo.
racerx Online work OP
racerx  Online Work OP
Mo.
A acceptable ring end gap 4 a (say 150 shot of the juice)on say a 500 cu.big block with a 693/703 roller,440-1,Ross pistons,eagle rods etc. Thax...
Re: Is there.... [Re: racerx] #188278
01/09/09 08:00 AM
01/09/09 08:00 AM
Mansfield, Tx
Jacob Pitt Offline
Jacob Pitt  Offline
Mansfield, Tx
Yes check with the ring makers they will have suggested ring end gaps.
2013 NHRA D4 Stock Champ
#4 in the World IHRA Stock
2x IHRA Div.4 Stock Champ
14x Track Champ
All using a Ultimate Converter Concepts converter. Call Lenny today 704-892-6837
Re: Is there.... [Re: racerx] #188279
01/09/09 08:20 AM
01/09/09 08:20 AM
LOWELL IN
Q
QWK_ENUF Offline
QWK_ENUF  Offline
Q
LOWELL IN
.005 x 1 in of bore
WAXER
Re: Is there.... [Re: racerx] #188280
01/09/09 01:42 PM
01/09/09 01:42 PM
Ring gap is real easy to get to tight, especilly on NOS I would set the top ring around .025 or larger, (your starting now with 150 HP NOS but what will it see total )and set the second ring at .028 or larger also. If you use these numbers DO NOT excede 200 HP on NOS system
Re: Is there.... [Re: Cab_Burge] #188281
01/09/09 11:03 PM
01/09/09 11:03 PM
Mo.
Mo.
Thax... fellas i'm going back 2 check my records 2 see what ring end gap my engine assembler has.Again Thax
