Re: 1971 Plymouth Satellite Sebring Plus, 90k (survivor)
[Re: gdonovan]
#1811132
04/24/15 08:16 PM
04/24/15 08:16 PM
Posts: 10,847 Oakdale CT
gdonovan
Oakdale CT
Road test!
No more squeaking speedo, blower motor works good, radio sounds great. Time to take a break and move onto another project for awhile.
Gary
"I think its got a hemi"
[Re: gdonovan]
#1811382
04/25/15 09:00 AM
04/25/15 09:00 AM
gdonovan
Oakdale CT
Many thanks to Kevin and James who helped me out with a few parts and information.
In the interior I still have to swap out the steering wheel and the car does need a little tuning work. The electronic distributor in the car has the wrong advance curve I think and the carb needs a touch of adjustment.
Still have to get the right air cleaner which I have not had time to pursue.
At least its turn-key now and everything is working as it should.
List of stuff that has been fixed-
Bad engine skip (1 plug, 1 wire, 1 valve) Repainted engine correct color Replaced power steering seal New battery New belts New plug wires New valve springs Correct alternator spacers Correct fuel line and replaced all rubber fuel hose Replaced a few bulbs NOS dash pad painted and installed Replaced horn buttons Re-skinned front seats Front speaker sent out to be refurbished Replaced missing parking brake handle Lubed speedo cable and speedo head Lubed blower motor (noisy) Polished gauge lens Adjusted shifter and took bow out of console plate Repaired armrest on door Repaired headliner
[Re: gdonovan]
#1811412
04/25/15 10:51 AM
04/25/15 10:51 AM
Posts: 3,106 Ridgeland Wi
mopars_1
Ridgeland Wi
I was glad to help! beautiful car no doubt.
1971 Plymouth Duster 340 auto 1937 Plymouth PT50 1969 Dodge Dart Swinger 340 4 speed 2013 Ram laramie 2500 hemi 2008 Harley FLSTSB springer
[Re: gdonovan]
#1881039
07/29/15 08:36 PM
07/29/15 08:36 PM
gdonovan
Oakdale CT
A friend wanted pictures of a few of the decals on the car for reference, here they are.
Mind you this is an LA built '71, might be in different locations on other plant vehicles.
[Re: gdonovan]
#1882714
08/01/15 03:44 AM
08/01/15 03:44 AM
Posts: 5,268 NY
70440+6bbl
NY
Thanks again for those great reference pics Gary! I put them to good use tonight :-)
'70 Super Bee 440 6 pack 4-spd 4.10 Dana N96 EB5 ‘70 Super Bee 440 6 pack 4-spd 3.54 Dana FC7 ‘70 ‘Cuda 440+6bbl 4-spd 3.54 Dana N96 EB5 V1W
[Re: 70440+6bbl]
#1882735
08/01/15 08:00 AM
08/01/15 08:00 AM
gdonovan
Oakdale CT
Thanks again for those great reference pics Gary! I put them to good use tonight :-) After a trip to the transfer station this morning will get the car off the lift and take some pictures of engine bay details for you. Gary
[Re: gdonovan]
#1882831
08/01/15 01:11 PM
08/01/15 01:11 PM
Posts: 5,268 NY
70440+6bbl
NY
[Re: gdonovan]
#1882861
08/01/15 02:27 PM
08/01/15 02:27 PM
gdonovan
Oakdale CT
Engine bay- Please note that there are a few things missing (ECS) and the car was converted to electronic sometime in its life. Use pictures with this in mind, clearly you can tell what is stock and what was tinkered with.
Gary
