Figuring Port Centerline Length #1882465
07/31/15 08:49 PM
07/31/15 08:49 PM
Menomonee Falls
DemonDust Offline OP
Menomonee Falls
How do you figure out port center line length?
Is there an easy way to figure out port center line length?
SDG Motorsports
Hellcat Demon and Redeye Supercharger CNC Porting
https://www.sdgmotorsports.com/
Re: Figuring Port Centerline Length [Re: DemonDust] #1882478
07/31/15 09:32 PM
07/31/15 09:32 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Simple... measure the outer/long length then measure
the short length..divide by 2... that is all the way
to the seat... string works real well... tape it all the
way
wave
Re: Figuring Port Centerline Length [Re: MR_P_BODY] #1882479
07/31/15 09:35 PM
07/31/15 09:35 PM
Menomonee Falls
Menomonee Falls
way
wave
If the head were chambers down. You're talking the floor and ceiling of the port?
SDG Motorsports
Re: Figuring Port Centerline Length [Re: DemonDust] #1882518
07/31/15 10:23 PM
07/31/15 10:23 PM
MR_P_BODY Offline
MR_P_BODY  Offline
way
wave
yep
wave
Re: Figuring Port Centerline Length [Re: DemonDust] #1882523
07/31/15 10:27 PM
07/31/15 10:27 PM
Menomonee Falls
Menomonee Falls
Thanks! I purchased the program you mentioned. Very informative. A few things could be explained a little better. But all in all seems like a pretty good program.
I like all the header combinations it gives you and tells you what they should do in theory.
SDG Motorsports
