How much gear for the 1/8 mile #188207
01/08/09 11:26 PM
01/08/09 11:26 PM
Bend, Oregon
67cuda340 Offline OP
super street
super street
Bend, Oregon
I am wondering how much gear I should be running
for the 1/8 mile. Currently I have 3.91's
I shift from second to third at the
1/8 mile. 6000 rpm's. 8.3 at 85mph.
The car is street driven/ not highway.
1973 Dodge Dart Sport
360
X heads
solid cam
727 manual valve body
3500 stall
drag radials 325/60/15's
thanks for input.
Matt
1973 Dodge Dart Sport 360 Drag radials 12.30 1/4 mile 7.82 1/8 mile
Re: How much gear for the 1/8 mile [Re: 67cuda340] #188208
01/08/09 11:34 PM
01/08/09 11:34 PM
land of 10,000______'s
BDS871Cuda Offline
BDS871Cuda  Offline
360
X heads
solid cam
3500 stall
thanks for input.
Matt
Guessing a 28" tire?
5.13's would do it.
What are your 60' times?
Snap your neck, mega G-force launch, is all I want!
Re: How much gear for the 1/8 mile [Re: 67cuda340] #188209
01/08/09 11:44 PM
01/08/09 11:44 PM
NC
barracuda man Offline
NC
I run the 5.13 but the 340 was out of breath at the finish line.Went to 4.88 and it pulls hard at the finish line now.
Re: How much gear for the 1/8 mile [Re: barracuda man] #188210
01/09/09 12:01 AM
01/09/09 12:01 AM
Bend, Oregon
super street
super street
Bend, Oregon
my 60 ft times are 1.9
thanks for the input.
Re: How much gear for the 1/8 mile [Re: 67cuda340] #188211
01/09/09 12:32 AM
01/09/09 12:32 AM
Central NC
gch Offline
gch  Offline
Central NC
I would think a 4.56 would be fine for max et.Even a 4.30 would work well.
Re: How much gear for the 1/8 mile [Re: gch] #188212
01/09/09 12:57 AM
01/09/09 12:57 AM
Raleigh N.C
hemiparts Offline
"Missile Pilot"
hemiparts  Offline
"Missile Pilot"
Raleigh N.C
I tried a 5.13 with a 28 and a 29.5 tire and my 340 would give up just before the lights. I'm going back to my 4.88's for this season.
Re: How much gear for the 1/8 mile [Re: 67cuda340] #188213
01/09/09 10:14 AM
01/09/09 10:14 AM
MR_P_BODY Offline
MR_P_BODY  Offline
It all depends on how many revs you want to pull
but 4.88 is a good over all gear for a SB. Figure
your rpm's at the traps then figure the % of gear
change you want.
Re: How much gear for the 1/8 mile [Re: 67cuda340] #188214
01/09/09 11:00 AM
01/09/09 11:00 AM
NC
440Jim Offline
440Jim  Offline
NC
Matt, unless you have a spare rear end center section setup with the new gears to swap out for street vs track, don't gear the car for 1/8 mile when it is a street car. I wouldn't even gear it for 1/8 mile if it was a race car unless it was something special, race gear it for 1/4 mile so you don't have to say "I can't run 1/4 mile my car is geared for 1/8"
That being said, if the mph at the 1/8 mark is the same, the gear change in a 727 from 2nd to 3rd is 1.45. So to cross the line in 3rd at the same rpm and mph as 2nd:
3.91 x 1.45 = 5.67
Now if you pick up some mph, say from 85 to 90, then use:
5.67 x 85/90 = 5.35
Re: How much gear for the 1/8 mile [Re: 440Jim] #188215
01/09/09 11:10 PM
01/09/09 11:10 PM
Bend, Oregon
super street
super street
Bend, Oregon
Jim,
What you are saying makes sense.
I really wont gain much if anything.
Matt
