1977 van wiring harness same as truck? #188203
01/08/09 11:07 PM
01/08/09 11:07 PM
Fort Lauderdale, FL
Suregrip Offline OP
Suregrip  Offline OP
Fort Lauderdale, FL
I found a new engine wiring harness for a 1977 dodge van with a 440. Is this the same engine harness for a 1977 dodge half ton with a 440? Part numbers are different but is there a difference and if so what is it?
Some people you just can't reach...
Re: 1977 van wiring harness same as truck? [Re: Suregrip] #188204
01/09/09 12:36 AM
01/09/09 12:36 AM
Carstairs, Alberta, Canada
dave571 Offline
dave571  Offline
totally different
The physical layout of a truck is like 180 degrees different than a truck.
Most of it will go across the firewall, which is over the front section of the engine, then branch off to where it needs to go. Nothing like a truck at all.
Sorry
