Page 9 of 13 1 2 7 8 9 10 11 12 13
Re: "Custom 33" [Re: Crizila] #1876376
07/23/15 02:05 AM
07/23/15 02:05 AM
Az
Crizila Offline OP
Crizila  Offline OP
Az
2 - 30 pound gas shocks worked nicely to hold the trunk lid open.
Fastest 300
Re: "Custom 33" [Re: Crizila] #1876941
07/23/15 11:19 PM
07/23/15 11:19 PM
Az
Crizila Offline OP
Crizila  Offline OP
Az
Custom 33 door jam / dome light switch solution.
Fastest 300
Re: "Custom 33" [Re: Crizila] #1876960
07/23/15 11:45 PM
07/23/15 11:45 PM
moparx Offline
moparx  Offline
that is a neat solution. mind if i "swipe" that idea ? grin
beer
Re: "Custom 33" [Re: moparx] #1876977
07/24/15 12:16 AM
07/24/15 12:16 AM
Az
Crizila Offline OP
Crizila  Offline OP
Az
beer
" Party down Garth!" bow
Fastest 300
Re: "Custom 33" [Re: Crizila] #1878288
07/26/15 08:53 AM
07/26/15 08:53 AM
moparx Offline
moparx  Offline
have you thought about a "suicide door lock" ? if so, would it be power or manual ?
beer
Re: "Custom 33" [Re: moparx] #1878334
07/26/15 11:33 AM
07/26/15 11:33 AM
Az
Crizila Offline OP
Crizila  Offline OP
Az
beer
Already installed - and for now, manual. Replaced the sound alarm that came with the kit with 2 red LED lights in the upper corners of the dash that will stay lit if the locks are not being engaged.
Fastest 300
Re: "Custom 33" [Re: Crizila] #1879190
07/27/15 03:25 PM
07/27/15 03:25 PM
IN
Matt Erich Offline
Matt Erich  Offline
IN
Here is the latest build for a customer in Florida. We finalized the color combo and will have this finished very soon.
Owner of Custom33.com 1933 Plymouth Coupe and Roadster Kits
Re: "Custom 33" [Re: Matt Erich] #1881181
07/29/15 11:02 PM
07/29/15 11:02 PM
Crofton, Ky.
rattler Offline
rattler  Offline
Crofton, Ky.
Hey Matt, thought you should know, one of your customers David (67hemi), suffered a stroke a couple of weeks ago. I am sure David will recover and finish his car, it will just take a little longer than planned.
1957 Dodge truck, Snakeskin Green with a little stroker motor. 1964 Plymouth Savoy wagon ( my new project)
Re: "Custom 33" [Re: Crizila] #1881557
07/30/15 03:25 PM
07/30/15 03:25 PM
IN
Matt Erich Offline
Matt Erich  Offline
IN
I have been in contact with his wife since it happened. I consider all my customers friend and check up on them and the builds very frequently. Hopefully he recovers quickly and back to 100%
Re: "Custom 33" [Re: Crizila] #1881969
07/31/15 01:11 AM
07/31/15 01:11 AM
Az
Crizila Offline OP
Crizila  Offline OP
Az
Power windows finally installed. Not a simple task on a door that is 3" wide ( ID ) at it's widest and the bottom of the door tapers down to about an inch. Did I mention the door is also curved!! Only system that would remotely work was "Specialty Power Windows" kit. As you can see from the pics, I had to do some home grown mounting work to gain the room I needed. Biggest problem was the taper at the bottom of the door - where the power window motor sits - ugh!
Fastest 300
Re: "Custom 33" [Re: Crizila] #1881976
07/31/15 01:19 AM
07/31/15 01:19 AM
Az
Crizila Offline OP
Crizila  Offline OP
Az
Got all the holes drilled in the dash and council. Dash, lt. to rt. = A/C heat vent, wiper switch, speedo, LED light for cooling fan system, Gauge cluster, below that HVAC controls, A/C heat vent. Council will house radio, speakers, clock, clock set button.
Fastest 300
Re: "Custom 33" [Re: Crizila] #1881979
07/31/15 01:21 AM
07/31/15 01:21 AM
Az
Crizila Offline OP
Crizila  Offline OP
Az
Added a little twist to the nerf bars.
Fastest 300
Re: "Custom 33" [Re: Crizila] #1893506
08/17/15 12:06 PM
08/17/15 12:06 PM
Az
Crizila Offline OP
Crizila  Offline OP
Az
Went with a simple exhaust system. No cross-over - straight through stainless "Borla's". Might have some loud issues down the road, so I went with stainless band clamps on the muffs for easier change if need be. Pipes will be black powder coated with heat paint.
Fastest 300
Re: "Custom 33" [Re: Crizila] #1893837
08/17/15 08:33 PM
08/17/15 08:33 PM
Lehigh Acres, Florida
rickstershemi Offline
Looks awesome.....is there room for a cross over pipe and be tucked up neatly....if one was desired...????
Re: "Custom 33" [Re: Crizila] #1894086
08/18/15 12:42 AM
08/18/15 12:42 AM
Az
Crizila Offline OP
Crizila  Offline OP
Az
Ya, I have room for an "H" pipe between the trans pan and trans mount and might do that at a later date. Finally turned one corner today and started disassembling it for paint. Frame will be powder coated black. Then body, fenders, cowl, hood back together and on the frame for painting.
Fastest 300
Re: "Custom 33" [Re: Crizila] #1902510
08/30/15 04:48 PM
08/30/15 04:48 PM
Az
Crizila Offline OP
Crizila  Offline OP
Az
As of yesterday, I took delivery of my 33 Plymouth from "Custom 33" one year ago. All systems have been installed (and tested where feasible ) and I am now in the process of disassembly for paint and interior ( last 2 big financial hits). Wife has been keeping financial track of everything ( I like to take my hits up front grin). Frame and some suspension pieces will be powder coated. Keeping to my original plan - respectable show piece with street functionality taking priority. Long trips attainable and 1/4 mile times in the mid to high 12's.
Fastest 300
Re: "Custom 33" [Re: Crizila] #1904182
09/01/15 04:12 PM
09/01/15 04:12 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Looks good!
- Stu Harmon
Re: "Custom 33" [Re: feets] #1911189
09/12/15 06:18 PM
09/12/15 06:18 PM
Az
Crizila Offline OP
Crizila  Offline OP
Az
Next stop after welding engine mounts, etc, will be to the powder coater.
Fastest 300
Re: "Custom 33" [Re: Crizila] #1922234
09/30/15 01:23 AM
09/30/15 01:23 AM
Az
Crizila Offline OP
Crizila  Offline OP
Az
Chassis back from powder coating and suspension hung back on. Most suspension pieces were done in Por 15 satin black. Next step will be to reinstall body, fenders, cowl, hood and send off for paint / interior work. Some wiring and brake master cyls will remain under the cowl and bagged. All else is outa there. got some junk wheels and tires to make it a "roller".
Fastest 300
Re: "Custom 33" [Re: Crizila] #1922455
09/30/15 01:35 PM
09/30/15 01:35 PM
dogdays Offline
dogdays  Offline
Please remind me how to apply POR-15. Spray or brush? Or how?
Thanks,
R.
