Who has info on weight of big block vs. small blk #188177
01/08/09 10:26 PM
01/08/09 10:26 PM
Southern California
GOT6PAK Offline OP
GOT6PAK  Offline OP
Southern California
I remember reading somewhere the difference in weight between an aluminum head, water pump and housing, intake big block VS. a cast iron small block. Does anyone have this info. I remember reading it was within 5 lbs. of the small block.
Re: Who has info on weight of big block vs. small blk [Re: GOT6PAK] #188178
01/09/09 12:47 AM
01/09/09 12:47 AM
Stow ,Ohio
demon440 Offline
demon440  Offline
Stow ,Ohio
Re: Who has info on weight of big block vs. small blk [Re: GOT6PAK] #188179
01/09/09 12:20 PM
01/09/09 12:20 PM
Kelowna, B.C. Canada
DPelletier Offline
DPelletier  Offline
No but here's a bump for you as this has always been an interesting question that nobody seems to be able to answer definatively.
I suspect that you could easily get a big block down to less than the weight of a stock small block using lightweight internals, aluminum heads, intake and waterpump housing, lightweight starter, headers, etc.
Of course there are those that will say "sure but the small block will still be lighter if you do the same things to it" but that kinda misses the point plus the weight gap would narrow as they got lighter.
1970 Super Bee 440 Six Pack 1974 'Cuda 2008 Ram 3500 Diesel 2006 Ram 3500 Diesel 2004.5 Ram 2500 Diesel 2003 Ram 3500 Diesel 2006 Durango Limited [url] http://1970superbee.piczo.com [/url]
Re: Who has info on weight of big block vs. small blk [Re: demon440] #188180
01/09/09 03:06 PM
01/09/09 03:06 PM
State of Corruption
camdog440 Offline
camdog440  Offline
State of Corruption
http://www.bigblockdart.com/techpages/engineweight.shtml
Those early hemi weights look kinda light! I thought just the BLOCK on the early hemi's weighed more than all the others.
Re: Who has info on weight of big block vs. small blk [Re: camdog440] #188181
01/09/09 03:11 PM
01/09/09 03:11 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
There's also a wildcard here. REPLACEMENT small blocks (R3, 340 Resto Blocks, etc.) are considerably heavier castings than original 318/340/360 blocks were. Most original blocks weighed in at around 165lbs with caps, replacement blocks are up around 220 (that's right in there with a vintage 440 or Hemi block!). Modern wedge and Hemi castings also wiegh allot more than vintage blocks.
So, it depends on which engine block you start with, not just which bolt on parts you use.
Re: Who has info on weight of big block vs. small blk [Re: ScottSmith_Harms] #188182
01/09/09 03:19 PM
01/09/09 03:19 PM
Ansonia, CT
CJK440 Offline
CJK440  Offline
Ansonia, CT
Out of the moparts tech archives.
Slant Six 475
273-340 "A" V8 525
360 "A" 550
361-383-400 V8 620
413-426W-440 V8 670
Street Hemi 765
2017 Contusion Blue Challenger T/A 392 M6 "BLKNBLU"
Re: Who has info on weight of big block vs. small blk [Re: CJK440] #188183
01/09/09 04:21 PM
01/09/09 04:21 PM
Escondido, CA. Ron Podsiadly,...
Mopar Ron Offline
Mopar Ron  Offline
lets use a 68 barracuda as the test car for this .
lets say you have a 340 barracuda with all stock parts(cast iron intake, exaust manifold and stock heads) and you put in a 440 with alum heads,alum water pump and wp housing, alum intake and tube headers. do you think that the 440 would weigh what the full dressed 340 was?
it appears that a 440 is 145# heaver than a 340
does anyone have real world # of the wight savings from 440 stuff like
headers vs exaust manifolds
alum heads vs stock 960's
alum intake vs cast iron(these could very depening on intake)
and alum water pump and housing vs stock cast stuff
and light weight start vs stock.
It would be interesting to see how close it comes to a stock 340 cuda weight
Re: Who has info on weight of big block vs. small blk [Re: Mopar Ron] #188184
01/09/09 07:43 PM
01/09/09 07:43 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
I know a factory Iron small block head weighs about 1 pound more than an iron big block 906
I figure aluminum from iron saves 20 pounds per head...a smallblock is more like 22.
BB Water pump housing saves 10 pounds, pump maybe 2. SB's already aluminum!
Intake I think I figure 35 iron 383 vs between 15 and 18 pound for aluminum.
aluminum radiator maybe 10-12
Lighter bobweight rotating assembly can easily save 6-8 pounds
B motor pushrods weigh ~1 oz less than RB....that's a pound right there!
Headers, too many variables, thick flange headers with 16 gauge tubes might be a wash compared to cast iron....cheapie 18 gauge with 1/4" flanges probably save 10 pounds each. Too many variables.
so I figure my installed aluminum low deck 517 with the radiator saves about 90 pounds over the the original 440 that the car came with.....or about the same as a factory 340 would weigh. it'd be a little lighter without the hard block but I'd rather have it in there
I don't think a bare 440 long block with an intake is really 120 pounds heavier than a 340, the block is roughly 60 pounds more but the heads and intake are probalby 10 pounds less (340 4bbls Iron is a comparatively heavy piece) but even adding the crank difference it's hard to find an answer that adds up to the other 60. But maybe it is over 100 with the manifolds.
Also Static weight probably isn't as big a factor as dynamic weight....stepping the aluminum heads not only lowers the mass and decreases the front weight bias...it also lowers the center of gravity. Dynamically taking off 10 pounds with an aluminum radiator hanging 2 feet ahead of the axle is like taking off 20 1 foot ahead
Your answers may vary but you really need to scale it if you want to know for sure. you can get carried a way...Ex: A holley is a few pouunds heavier than an aluminum carter
WIZE
In Car:
Re: Who has info on weight of big block vs. small blk [Re: Streetwize] #188185
01/10/09 12:39 PM
01/10/09 12:39 PM
Southern California
GOT6PAK Offline OP
GOT6PAK  Offline OP
Southern California
Thanks guys, I keep forgetting about the bazillion variables It sounds like a big block fitted with aluminum goodies gets it real close to an all cast iron small block(within a few pounds).
