Re: Max Wedge electric cutouts
[Re: ryangtogtx]
#1881945
07/31/15 12:38 AM
07/31/15 12:38 AM
Posts: 12,248 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
You don't HAVE to mount the cut-outs directly to the collectors. Just move them back and use something like an adapter. Mine are behind the tranny cross member.
Or cut the 3 bolt flange off the cut-outs and weld on a 4 bolt.
Master, again and still
[Re: ryangtogtx]
#1882056
07/31/15 09:21 AM
07/31/15 09:21 AM
Posts: 17,924 Akron, Ohio
ProSport
Akron, Ohio
Ryangtogtx, is this a street car or street/strip car? My car is street only, I don't do any tuning for open and closed. If I raced it I would check plugs and mph and make a jet change if needed. Electric cutouts are extremely fun, mine are from DMH.
[Re: Randy..]
#1882080
07/31/15 10:46 AM
07/31/15 10:46 AM
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Are you gonna tune for open pipes or closed exh, be fat closed be lean open and vise versa. I have had cut-outs on several different cars, including a couple that I ran in KOS. None of them needed different tunes.
[Re: ryangtogtx]
#1882665
08/01/15 02:11 AM
08/01/15 02:11 AM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
I run 3" cutouts, not electric though. Takes me less than 5 minutes to loosen 6 bolts, so I don't see the need. You can generally find a happy medium tune, but its gonna be a little rich on the street and a little lean at the track. I now have quick-jet-change fuel bowls, so last few times at the track I've made some jet adjustments, and found nearly a tenth over the street / corked up jetting.
