Re: aluminum case 18 spline 4 speed.
[Re: joelson6]
#1881745
07/30/15 09:13 PM
07/30/15 09:13 PM
Posts: 4,457 Washington
madscientist
Washington
Yup...good for parts only. PM me and we'll make a deal on the parts!
Seriously, I'd pull it apart to get a good look at it, touch up the sliders and rings and run it. PITA sometines to drive on the street but I have done it. My current deal is slick shifted with syncros. Works like a charm.
[Re: joelson6]
#1881922
07/31/15 12:19 AM
07/31/15 12:19 AM
Posts: 4,243 Charlotte, North Carolina
sgcuda
Gears and sliders are done by Liberty Gears http://www.libertysgears.com Like already stated, good forks are installed. Also, side cover is the preferable one. Should work for a while in its present condition. Gears can be serviced (lug rings replaced). Sliders will eventually need replacement. None of it is terribly expensive. I don't like the looks of 2nd gear. Lots of pitting. If race intended, I think I would replace it. Also, check the cluster gear assembly for the same condition. Pics look like rust condition.
[image][/image]
[Re: joelson6]
#1882052
07/31/15 08:44 AM
07/31/15 08:44 AM
Posts: 863 Pinelands , NJ
joelson6
Pinelands , NJ
thanks stanton. your right, it is an OD case. figured out the VIN stamped on it is 1977 St. Louis plant. they built Aspen/Volare in '77 there.
[Re: joelson6]
#1882365
07/31/15 05:38 PM
07/31/15 05:38 PM
Posts: 9,100 Rogue River, OR
Jeremiah
Rogue River, OR
the countershaft is definitely not loose in the case.
so from what your saying, it's only good for parts? If you re-read what I wrote above I said if the case is bushed, which it is, you could probably get your money out of it by parting it out because it has many desirable race-oriented parts. That said the pro-shifted stuff has been outdated by the superior "face plate" design. The face plate design uses much wider spacing and bigger "dogs" or lugs that increase durability and the "shift window". If it was me and I wanted to go bang some gears I'd dress the dogs on the gears, inspect everything carefully during rebuild and run it. It will be really fun to drive! If you are really paranoid you can have the gears/case magnafluxed. I'll attach a pic the instructions for you.
[Re: joelson6]
#1882651
08/01/15 01:47 AM
08/01/15 01:47 AM
Posts: 1,406 New Jersey, USA
yella71
New Jersey, USA
some one custom built that trans. put it in your car and beat it like a redheaded stepchild.
71 challenger convertable, 64 sport fury 383 ci with factory air
99 sebring convertable
89 CTD pup
[Re: joelson6]
#1882722
08/01/15 04:33 AM
08/01/15 04:33 AM
Jeremiah
Rogue River, OR
thanks for all the info. i really don't know too much about the internals of the 4 speeds. never took one apart myself. that's kind of ironic cause most of my cars are 4 speeds. i do have an empty 18 spline cast iron case that i've had since the 90's. a friend of mine is gonna help me swap the cases. he's had these pro shift trans before. i wanna try it in my '74 challenger. i'm setting it up more for the track than the street. this year i upgraded to QA1 double adj. all the way around, strange 1350 driveshaft and yokes. and i have the RXT dual disc clutch. i have a 2 step and i have to setup the clutch pedal switch for the launches. maybe this trans is what i need for the track. once again, thanks for the info! you guys are great! Let us know how it works out! If you want to part with that aluminum case let me know. I can always use spares! If you are going to hammer on it I'd use a billet bearing retainer. My last clutch failure started with a cracked retainer. I'd also call up Imperial Serices and order a poly transmission mount.
[Re: Sixpak]
#1886075
08/06/15 01:47 AM
08/06/15 01:47 AM
Jeremiah
Rogue River, OR
It's what they used to call a crash box. For drag cars - use the clutch once at the start, shift gears under power while NOT using the clutch. Gotta pull hard and fast though, no leisurely shifting thru the gears. And usually you don't try downshifting like with a normal trans. Largely been replaced by Jerico and Liberty specialty made drag car manual transmissions. If you read the "Notes" section in the Liberty install sheets I posted is states that "you MUST use the clutch in all gears".
[Re: Z_Z]
#1886076
08/06/15 01:48 AM
08/06/15 01:48 AM
Jeremiah
Rogue River, OR
Jeremiah..I was gonna ask you if that was a billet retainer but you already answered it for me. Where did you get yours?..I have the same setup there, and did the first gear syncro and side cover mod..so it could be a possibility that my retainer could be cracked then. I usually buy my stuff from Passon Perfomance unless he is too busy. Post up a thread about your ride, we would love to see it.
[Re: Jeremiah]
#1886324
08/06/15 04:00 PM
08/06/15 04:00 PM
Posts: 8,307 fredericksburg,va
cudaman1969
fredericksburg,va
It's what they used to call a crash box. For drag cars - use the clutch once at the start, shift gears under power while NOT using the clutch. Gotta pull hard and fast though, no leisurely shifting thru the gears. And usually you don't try downshifting like with a normal trans. Largely been replaced by Jerico and Liberty specialty made drag car manual transmissions. If you read the "Notes" section in the Liberty install sheets I posted is states that "you MUST use the clutch in all gears". Or let it hit the rev limiter, that monetary drop will let it shift.
