Turn key to start with motor running and destroyed batt
#188127
01/08/09 08:42 PM
01/08/09 08:42 PM
Posts: 1,128 Tulsa, OK
73cudaproject
Tulsa, OK
A couple days ago I was distracted and accidently turned the key to start on my 2001 Dakota. Immediately the truck quit running and all electrical items shut down. I then tried to start the truck and absolutely nothing happened when I turned the key to start; however a few minutes later electrical items started to sort of work and when I turned the key to start the starter made the clicking sound. I eventually jumped the battery and the truck would run if I keep the rpms high but die if I tried to let it idle. After I noticed the electric windows worked very slow I felt confident that whatever happened destroyed the battery. Is it possible for the starter to engage and then work in reverse as a generator and overload the battery? I installed a new battery and everything seems to be back to normal.
Re: Turn key to start with motor running and destroyed batt
[Re: volaredon]
#188131
01/08/09 09:28 PM
01/08/09 09:28 PM
73cudaproject
Tulsa, OK
If it was running and your accessories were slow to respond I'd suspect the alternator's not charging that battery; also by chance is that the orig battery? If so it has definitely outlived its usefullness.
The battery was an almost brand new replacement battery which was working perfectly prior to when I accidently turned the key to start. Instead of the typical grinding of gears when this happens the engine immediately quit running and everything went dark. When I turned the key to start nothing happened so at first I thought I must have blown some type of main fuse but then a minute or so later the clock radio came back on, the dash lights started to work, etc. After I got is started I actually started to two foot drive it to get a battery but the electronic transmission was operating strangely and then AAA arrived so after discussing with him he openned the hood and had me get off the accelerator which caused the motor to die. After reviewing the situation agreed the first place to start is with a new battery so he took me to buy a new battery which immediately fixed the problem.
[Re: stumpy]
#188133
01/08/09 09:39 PM
01/08/09 09:39 PM
73cudaproject
Tulsa, OK
I can't believe hitting the key with the engine running would have anything to do with battery failure.The starter wouldn't ingage so it wouldn't be spun by the motor. The grinding you hear is the starter teeth not meshing with the flywheel.Beside that it's been done to often by others without battery failure.It was just a fluke that the battery failed when it did.
I realize how odd this must sound but I think the battery did not instantly die at this very moment. IMO the fluke is somehow it did cause this battery to immediately get overloaded and fail.
[Re: aarcuda]
#188138
01/09/09 02:06 PM
01/09/09 02:06 PM
73cudaproject
Tulsa, OK
probably half tripped a circuit breaker or a fuseable link somewhere and you are not getting correctr system voltage to the computer so its not running right until you up the rpms to allow the alternator to output sufficient voltage to run the system...
I actually fixed the problem by installing a new battery. I am from Tulsa and this happened in Laramie. I installed the new battery and left the truck with my son. So far everything is back to normal.
[Re: MoparforLife]
#188140
01/09/09 02:10 PM
01/09/09 02:10 PM
Posts: 21,832 Kirkland, Washington
Pacnorthcuda
If the battery charge was marginal, turning the key and energizing the starter may have drawn enough current to overload the the already nearly dead battery and there for killing any electrical power needed to run the engine. The reason for running at higher RPM's and dying at idle is that with a dead or nearly battery and jump starting the engine was running on the alternator charge which wasn't enough at idle to keep voltage to the ignition up to firing voltage.
That explaination follows logic. I too think the power draw killed the ignition. My only question would be is the charging system operating correctly?
[Re: 73cudaproject]
#188141
01/09/09 02:12 PM
01/09/09 02:12 PM
Posts: 15,491 the boonies
aarcuda
the boonies
hmmmm, that is looking like a bad battery. I seriously doubt the starter could back charge a battery and destroy it without blowing the internal windings or brushes in the starter out or melting the starter cable.
[Re: 73cudaproject]
#188142
01/09/09 08:16 PM
01/09/09 08:16 PM
Posts: 511 Jasper, Indiana
fastnos
Jasper, Indiana
My best guess... Is the battery was marginal at best. Being winter time, you tax your electrical system even more then normal like in the summer time. Heater, headlights, defroster, wipers,(sometimes heated mirrors, seats, Gps display, Ipods, Amps ect...) they all take a little more then normal load. Short trips and cold weather will over-tax your charging system, especially with a bad battery. I was taught a charging system was designed to maintain a charge, not to constantly keep charging, although it will for awhile. I would imagine (without looking at it ) you might even had slightly corroded connections too. (This might have been taken care of when you changed out the battery.) Then figure in some short trips, or long periods of idleling, with all the accesories on, with no time to charge battery back to full charge. Then if you had a shorted cell, all these would cause your battery to have a lower output. All of these might have been enough to put the battery over the acceptable discharge range. 3 questions now, 1) Did you have them charge and check your old (possibly good) battery? If they just tried to check it while it was discharged/low, that won't give you an accurate reading. 2) Have you had anyone check the output on your alternator after you changed out the battery? It may not be putting out as much as it used too either. 3) How old was the battery? 4-5 years is average, but really depends on how it was used, maintained, and how much it was discharged and re-charged-lots of accessories?
A True Hybrid: Burns Gas AND Rubber!
