Poor spark off coil #1880902
07/29/15 04:44 PM
07/29/15 04:44 PM
Western., NY
sco440 Offline OP
sco440  Offline OP
Western., NY
72 RR, newly rebuilt 440 engine, I cannot get a good strong consistent spark off the coil wire. I get an intermittent spark.
I got no spark from the plug wire when coil wire is plugged into the distributor.
Any ideas?
new Orange 4 pin ECU,
new 5 pin ecu engine wiring harness, green wire with red tracer has no ECU pin
new CraneCam Fireball PS50 coil
new CraneCam Firewire plug wires
new 4 plug ballast resistor
'72 Road Runner
'72 Dart Swinger 340
'12 Challenger R/T
Re: Poor spark off coil [Re: sco440] #1881098
07/29/15 09:46 PM
07/29/15 09:46 PM
intermittent spark from coil wire to ground & no spark to any of the plugs? Correct? start by checking the reluctor gap (want .008" at rest). Confirm that it is wired correct & the coil is being fed thru the ~.5 ohm half of the 4 terminal ballast & as you noted the other half to the red/green ECU terminal ain't used in a 4 pin ECU app. that'll get us started
Re: Poor spark off coil [Re: sco440] #1881563
07/30/15 03:30 PM
07/30/15 03:30 PM
Western., NY
sco440 Offline OP
sco440  Offline OP
Western., NY
Update, I got a better ground for the ECU box. Now I have great spark from the coil wire out. When I hook the coil wire to the distributor, I get no spark at any of the plugs. I put in a new pickup into the distributor. Rechecked airgap at .008, new rotor, new cap. Still no spark. Took cap off, rotor spins fine. The distributor was an off brand electronic unit bought off ebay. It must be a bad/wrong distributor? I ordered a Summit Racing Electronic Mopar Distributor SUM-850005. I don't know what direction to go if I still don't get spark at the plug wires.
'72 Road Runner
'12 Challenger R/T
Re: Poor spark off coil [Re: sco440] #1881612
07/30/15 04:55 PM
07/30/15 04:55 PM
Cleveland
sunroofgtx Offline
sunroofgtx  Offline
Cleveland
You'll get a spark, no worries. Give me a call if you like. We can go through some "checks"
Join the quickest team in motorsports. Team FireCore. CustomWiresets.com
Re: Poor spark off coil [Re: sunroofgtx] #1881910
07/31/15 12:11 AM
07/31/15 12:11 AM
if the coil is putting out/delievering sparks to the coil wire plugged into the center cap terminal as the dist rotor/shaft turns then all that is left in the secondary current path from the center cap post to the plugs is the cap (replaced) rotor (replaced) & some if not all of the plug wires at least have continuity & these tend to be trouble free items, cap/rotor expecially & secondary voltage is intense & it takes alot to side track it (we're missing sumpin easy but I ain't seeing what it is)
