Re: 0-20 lb tire pressure gauge
[Re: TheOtherDodge]
#1880613
07/29/15 11:15 AM
07/29/15 11:15 AM
Challenger 1
Cincinnati, Ohio
I have a 0-15 lb Moroso but with my drag radials I need something that goes to 20 lbs. Any suggestions on which is the best?
Thanks! Replace the gauge with a 0-30# gauge, use the same hose and air chuck. Link
[Re: TheOtherDodge]
#1880622
07/29/15 11:32 AM
07/29/15 11:32 AM
Posts: 7,506 Az
Crizila
Az
Think Jegs is running a sale on air gauges right now - 15, 30, 60 lb gauges. They look pretty good.
Fastest 300
[Re: TheOtherDodge]
#1880632
07/29/15 11:45 AM
07/29/15 11:45 AM
Challenger 1
Cincinnati, Ohio
I really don't want one that goes to 30 lbs as I will never go past 20. The smaller the greatest reading will allow for more in between increments.
I can't use my current gauge for fuel pressure because I run FI on everything I own. A 0-30# will be the most accurate for you. Always want your readings in the middle of the scale. BTW the CSI one is the most expensive air gauge that I know about, you asked what was best.
[Re: TheOtherDodge]
#1880649
07/29/15 12:07 PM
07/29/15 12:07 PM
Posts: 19,363 Las Vegas
Al_Alguire
Las Vegas
We bought a couple of these. They work very well and match my high dollar Longacre and Moroso gauges. They have increments of .1 lbs
http://www.ebay.com/itm/151697783180?_trksid=p2060353.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
