Will hollow pushrods work on a stock type 318 ?? #188060
01/08/09 06:49 PM
01/08/09 06:49 PM
Almost, South Dakota
BEELINE Offline OP
BEELINE  Offline OP
I am rebuilding a 67 318 with a small Comp hyd. cam. I am using the stock rockers over. The block/heads were milled a total of .050 and Comp cams has a .050 shorter pushrod (part number 7956-16) but it is a hollow smallblock chevy type. The lifters are also oil through.
Will there be an oil pressure problem with the oil coming up through the pushrod and out the oil hole in the rocker arm cup? Both Comp and Mancini list the same pushrod for this application but they give no details. Anybody here have any experience with this application?
Re: Will hollow pushrods work on a stock type 318 ?? [Re: BEELINE] #188061
01/08/09 07:36 PM
01/08/09 07:36 PM
GMP440 Offline
GMP440  Offline
Shouldn't be a problem. Stock 318's came with hollow pushrods.
Re: Will hollow pushrods work on a stock type 318 ?? [Re: GMP440] #188062
01/08/09 10:13 PM
01/08/09 10:13 PM
My 318 ones were not hollow. If the lifters oil thru the top(most do) with hollow pushrods that would loose too much pressure & a non magnum valve train gets all it needs from the passage from the cam on each side.
Re: Will hollow pushrods work on a stock type 318 ?? [Re: RapidRobert] #188063
01/08/09 11:11 PM
01/08/09 11:11 PM
MARYLAND
69Cuda340S Offline
69Cuda340S  Offline
MARYLAND
Run the oil pump with the intake off. Not much oil bleeds out of the top of those lifters. I don't think its going to be a problem.
Re: Will hollow pushrods work on a stock type 318 ?? [Re: 69Cuda340S] #188064
01/08/09 11:16 PM
01/08/09 11:16 PM
Hampton, Ga.
70dart360 Offline
Green Meister
70dart360  Offline
Green Meister
Hampton, Ga.
You'll probably lose a little pressure, but ya also gotta think about the strength in solid versus hollow push rods. I had a 318 2 bbl that had them, never had an oil pressure problem but did break some spinning it out in the rain and taching it up. Dumb kids.
70 Dart Swinger 72 D-100 440 shortbed 76 Pinto, 68k 21mpg!
