Fire Core Dizzy Question #1879671
07/28/15 12:34 AM
07/28/15 12:34 AM
Mesa, Arizona
dart4forte Offline OP
Mesa, Arizona
Wondering if the ballist resister is used or nor with the Firecore plug n play?
Abe Lincoln
Re: Fire Core Dizzy Question [Re: dart4forte] #1879767
07/28/15 02:30 AM
07/28/15 02:30 AM
WA
tman Offline
tman  Offline
WA
Its dependent on your ignition box or ecu not distributor. So if you are using a Mopar box, you will need resistor. Unless you got the Ready to Run distributor, then you don't need it including the ignition box.
Re: Fire Core Dizzy Question [Re: tman] #1879901
07/28/15 11:21 AM
07/28/15 11:21 AM
Mesa, Arizona
Mesa, Arizona
Yes, I have the ready to run so it doesn't use a box.
Abe Lincoln
Re: Fire Core Dizzy Question [Re: dart4forte] #1880111
07/28/15 03:46 PM
07/28/15 03:46 PM
dogdays Offline
dogdays  Offline
Shouldn't use the Ballast resistor, IIRC. I believe the module is similar to early GM HEI and those took 12V straight in.
R.
