Anyone use the C.A.P. Dynamic Strut Bars? #187939
01/08/09 04:19 PM
01/08/09 04:19 PM
Mopar Lane,Mississippi
67HEMI Offline OP
67HEMI  Offline OP
I am trying to free up some movement in my 67 Coronet front suspension and at the same time lose some weight. Anyone use these or have a better alternative? In principle looks like they would allow easier movement of the lower control arms since there are no bushings.
'33 Plymouth 5 Window Coupe Blown Aluminum HEMI w/bolt ons (under construction) '69 Chrysler 300 Convertible 375 HP 440 '71 Plymouth Duster 360 W/EFI (Wife's Ride) '12 Ram MegaCab Dually 6.7 Cummins
Re: Anyone use the C.A.P. Dynamic Strut Bars? [Re: 67HEMI] #187940
01/08/09 06:04 PM
01/08/09 06:04 PM
GO BUCKS !!!!!!!
3
340RICK Offline
340RICK  Offline
GO BUCKS !!!!!!!
Yes it makes a big difference with a rod end compared to that big bushing just binding up as the wheel travels.
I have Bondo Bobs struts on my car and with no shock on the car you can move the spindle up and down thru out its full range of motion with one hand easily.
Then you can use the shock to control the front end.
Check out Bobs before you buy www.bobsprofab.com
Re: Anyone use the C.A.P. Dynamic Strut Bars? [Re: 340RICK] #187941
01/09/09 03:51 PM
01/09/09 03:51 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
You guys might be interested in what I saw last week. A friend of mine is restoring one of Bobby Alisons NASCAR Daytonas. In place of the the strut rod bushings are factory Chrysler upper ball joints. The hole is opened up and the hex of the joint is welded to the front flat of the K-frame. A rod is threaded onto the ball joint stud which goes back to the lower A-Arm. This allows for some caster adjustment as well. Granted it would be a pain to change the ball joint but I dought if it would ever wear out with such little movement. Pretty easy & inexpensive.
Doug
Re: Anyone use the C.A.P. Dynamic Strut Bars? [Re: 340RICK] #187942
01/10/09 11:32 AM
01/10/09 11:32 AM
67HEMI Offline OP
67HEMI  Offline OP
Thanks for the info.I called Bob yesterday and he does not have the dynamic bars to fit stock lower control arms. Guess I will order the CAPS Monday.
Re: Anyone use the C.A.P. Dynamic Strut Bars? [Re: 67HEMI] #187943
01/10/09 11:52 AM
01/10/09 11:52 AM
sycamore,ohio
BobsProFab Offline
BobsProFab  Offline
sycamore,ohio
i am not tooled up right now to make the machined part for the mounting into the stock control arm to make them fully adjustable without pulling the strut to adjust it.
i will look into machining them in the near future
Bob
Re: Anyone use the C.A.P. Dynamic Strut Bars? [Re: BobsProFab] #187944
01/10/09 11:59 AM
01/10/09 11:59 AM
Helsinki, Finland
Anselmi Offline
Anselmi  Offline
Helsinki, Finland
'66 Plymouth
'64 Dodge
'63 Plymouth x 3
Re: Anyone use the C.A.P. Dynamic Strut Bars? [Re: Anselmi] #187945
01/10/09 12:06 PM
01/10/09 12:06 PM
sycamore,ohio
BobsProFab Offline
BobsProFab  Offline
sycamore,ohio
How about Bill Reilly's?
http://www.reillymotorsports.com/store/home.php?cat=266
mine are like Bills, fixed in the lower control arm.
I make mine from Chromoly.
Re: Anyone use the C.A.P. Dynamic Strut Bars? [Re: dvw] #187946
01/12/09 10:40 PM
01/12/09 10:40 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
You guys might be interested in what I saw last week. A friend of mine is restoring one of Bobby Alisons NASCAR Daytonas. In place of the the strut rod bushings are factory Chrysler upper ball joints........Pretty easy & inexpensive.
Doug
I have seen that also, but, a ball joint is not designed for any real loading in a straight pull as used in a strut. So Either the pulling forces are not that great to begin with, or the ball joint is just strong enough for limited? Nascar use. Or something else.
