440-1 heads #187915
01/08/09 04:00 PM
01/08/09 04:00 PM
usa
hot67cuda Offline OP
usa
is it ness ary to use a off set roller lifter with these heads and there .800 off sea rocker arms.
Re: 440-1 heads [Re: hot67cuda] #187916
01/08/09 04:05 PM
01/08/09 04:05 PM
Upstate NY
Bigcube Offline
Bigcube  Offline
Upstate NY
I use offset lifter's on the intake side only. I have jesel offset rockers.
Re: 440-1 heads [Re: hot67cuda] #187917
01/08/09 04:07 PM
01/08/09 04:07 PM
NO
Some mega blocks and a few others require some grinding on the block for pushrod room at or near the deck of the block ( you will see where at mock up ) the push rods are in at an angle and it is said that there is some power in going with offset lifters and getting them straight but unless you have the lifter bores bushed you can't use them as the only offset lifters available are not solid body and could cause oil pressure issues go with standard lifters and let her rock!
Re: 440-1 heads [Re: hot67cuda] #187918
01/08/09 09:34 PM
01/08/09 09:34 PM
NC
440Jim Online work
440Jim  Online Work
NC
You must use the offset rocker arms. But only a few applications need to use the offset lifters.
Re: 440-1 heads [Re: 440Jim] #187919
01/08/09 09:51 PM
01/08/09 09:51 PM
UK
602heavy Offline
602heavy  Offline
UK
Interesting , i've got solid roller lifters with offset intakes , mega block with jessel valve gear on 573-13 heads , are you saying the lifter bores should be bushed? , the pushrods don't come straight up either.
Re: 440-1 heads [Re: hot67cuda] #187920
01/08/09 10:29 PM
01/08/09 10:29 PM
usa
usa
I was concerned about the angle from 440-1 rocker arm to a standard roller lifter.
Re: 440-1 heads [Re: hot67cuda] #187921
01/08/09 10:55 PM
01/08/09 10:55 PM
Plymouth Meeting, PA
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
I use a 400 deck height block with my 440-1's and use standard lifters.
BB, TT5,Procharged 3300lb Street Car 4.79/154
Re: 440-1 heads [Re: bigtimeauto] #187922
01/08/09 11:00 PM
01/08/09 11:00 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
I ran the standard offset full body Comp solid roller lifters for years, using the Jesel 1.7 rocker system. This was with a 71 year 440 block.
Re: 440-1 heads [Re: ] #187923
01/08/09 11:05 PM
01/08/09 11:05 PM
AndyF Offline
AndyF  Offline
. . .but unless you have the lifter bores bushed you can't use them as the only offset lifters available are not solid body and could cause oil pressure issues go with standard lifters and let her rock!
Not true any longer. You can get solid roller lifters from IMM that have the intakes offset by 0.180. The IMM roller lifters oil the pushrod and the roller wheel and work just fine in an unbushed block.
Re: 440-1 heads [Re: AndyF] #187924
01/08/09 11:51 PM
01/08/09 11:51 PM
usa
usa
I've never herd of those lifters before.
Re: 440-1 heads [Re: hot67cuda] #187925
01/09/09 02:17 AM
01/09/09 02:17 AM
SoCal
Brian Hafliger Offline
SoCal
We helped design these for Comp.
Brian
Re: 440-1 heads [Re: bigtimeauto] #187926
01/09/09 03:59 AM
01/09/09 03:59 AM
Mo.
racerx Offline
racerx  Offline
Mo.
What he said
Re: 440-1 heads [Re: hot67cuda] #187927
01/09/09 01:42 PM
01/09/09 01:42 PM
AndyF Offline
AndyF  Offline
Well that is why you come to Moparts! Where else are you going to find out about the cool new stuff?
Re: 440-1 heads [Re: AndyF] #187928
01/09/09 02:16 PM
01/09/09 02:16 PM
SW pa
goldenlancer Offline
SW pa
I should of used the off set lifters with my victors. it would have made the pushrod clearance much easier. (a lot less grinding and machining) but of course when the victors came out nobody knew exactly what to do.....
N/SS
Re: 440-1 heads [Re: Brian Hafliger] #187929
01/12/09 11:53 PM
01/12/09 11:53 PM
AndyF Offline
AndyF  Offline
This picture might be a little better.
