Re: 440-1 heads
[Re: hot67cuda]
#187916
01/08/09 04:05 PM
01/08/09 04:05 PM
Posts: 10,384 Upstate NY
Bigcube
Upstate NY
I use offset lifter's on the intake side only. I have jesel offset rockers.
Re: 440-1 heads
[Re: hot67cuda]
#187917
01/08/09 04:07 PM
01/08/09 04:07 PM
NO Some mega blocks and a few others require some grinding on the block for pushrod room at or near the deck of the block ( you will see where at mock up ) the push rods are in at an angle and it is said that there is some power in going with offset lifters and getting them straight but unless you have the lifter bores bushed you can't use them as the only offset lifters available are not solid body and could cause oil pressure issues go with standard lifters and let her rock!
Re: 440-1 heads
[Re: bigtimeauto]
#187922
01/08/09 11:00 PM
01/08/09 11:00 PM
Posts: 6,293 Rock Springs
Bob_Coomer
Rock Springs
I ran the standard offset full body Comp solid roller lifters for years, using the Jesel 1.7 rocker system. This was with a 71 year 440 block.
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
Re: 440-1 heads
[Re: ]
#187923
01/08/09 11:05 PM
01/08/09 11:05 PM
Posts: 31,045 Oregon
AndyF
. . .but unless you have the lifter bores bushed you can't use them as the only offset lifters available are not solid body and could cause oil pressure issues go with standard lifters and let her rock!
Not true any longer. You can get solid roller lifters from IMM that have the intakes offset by 0.180. The IMM roller lifters oil the pushrod and the roller wheel and work just fine in an unbushed block.
Re: 440-1 heads
[Re: hot67cuda]
#187925
01/09/09 02:17 AM
01/09/09 02:17 AM
Posts: 5,486 SoCal
Brian Hafliger
SoCal
I've never herd of those lifters before.
We helped design these for Comp. Brian
Re: 440-1 heads
[Re: bigtimeauto]
#187926
01/09/09 03:59 AM
01/09/09 03:59 AM
Posts: 4,071 Mo.
racerx
Mo.
I use a 400 deck height block with my 440-1's and use standard lifters.
What he said
