Freeze plugs leaking in 440 What's best to use? #187880
01/08/09 03:01 PM
01/08/09 03:01 PM
Southern California
GOT6PAK Offline OP
GOT6PAK  Offline OP
Southern California
Engine is rebuilt with only 2 hours break in time on stand. The freeze plugs in the block are leaking and I'm wondering what to replace them with(brass, steel etc.)?
Re: Freeze plugs leaking in 440 What's best to use? [Re: GOT6PAK] #187881
01/08/09 03:07 PM
01/08/09 03:07 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
Brass plugs and wipe a little permatex form-a-gasket (the fully curing version) in the block first.
Re: Freeze plugs leaking in 440 What's best to use? [Re: Neil] #187882
01/08/09 03:14 PM
01/08/09 03:14 PM
Southern California
GOT6PAK Offline OP
GOT6PAK  Offline OP
Southern California
Any idea what that's called so I get the right thing?
Re: Freeze plugs leaking in 440 What's best to use? [Re: GOT6PAK] #187883
01/08/09 03:21 PM
01/08/09 03:21 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
Should say 1B on the bottom of the tube.
Re: Freeze plugs leaking in 440 What's best to use? [Re: GOT6PAK] #187884
01/08/09 03:25 PM
01/08/09 03:25 PM
I prefer steel ones, I think they grip the block tighter, yes they do not rust but mine will get changed out well before rust thru becomes an issue but many are totally happy with brass ones. I use the dorman brand which are much deeper than some of the shallow ones that are in the "pioneer" blister packed kits. I would use permatex #1(in the toothpaste tube).
Re: Freeze plugs leaking in 440 What's best to use? [Re: GOT6PAK] #187885
01/08/09 03:33 PM
01/08/09 03:33 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
I guess they weren't replaced when the engine was rebuilt? I like brass.
I rebuilt a 340 in 1986 and they rusted out last summer. I used steel then and put in brass last summer, wish I would have used brass back in 86.
Re: Freeze plugs leaking in 440 What's best to use? [Re: Challenger 1] #187886
01/08/09 06:38 PM
01/08/09 06:38 PM
Athens, Greece
Pyper70 Offline
Pyper70  Offline
Athens, Greece
I have seen Stainless steel ones....how do those compare?
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
Re: Freeze plugs leaking in 440 What's best to use? [Re: Pyper70] #187887
01/08/09 07:10 PM
01/08/09 07:10 PM
Southern California
GOT6PAK Offline OP
GOT6PAK  Offline OP
Southern California
The freeze plugs are new on my 440, but they leak. I went to Mazzolini's shop a few minutes ago and bought new ones, his are the deeper ones. I just looked at my 440 and it has the shallow ones. I bought another can of "The Right Stuff" and will put the new ones in tonight .
Re: Freeze plugs leaking in 440 What's best to use? [Re: GOT6PAK] #187888
01/08/09 07:24 PM
01/08/09 07:24 PM
brass or steel
Re: Freeze plugs leaking in 440 What's best to use? [Re: RapidRobert] #187889
01/08/09 08:33 PM
01/08/09 08:33 PM
Southern California
GOT6PAK Offline OP
GOT6PAK  Offline OP
Southern California
Sorry, brass.
Re: Freeze plugs leaking in 440 What's best to use? [Re: GOT6PAK] #187890
01/08/09 08:34 PM
01/08/09 08:34 PM
I'll get over it
Re: Freeze plugs leaking in 440 What's best to use? [Re: RapidRobert] #187891
01/08/09 09:20 PM
01/08/09 09:20 PM
Georgia
Matt M Offline
Matt M  Offline
Georgia
I had one rust out on me.
I was "lucky" it happened to be the one behind the exaust manifold on the drivers side.
Re: Freeze plugs leaking in 440 What's best to use? [Re: Matt M] #187892
01/08/09 10:17 PM
01/08/09 10:17 PM
abodyman Offline
super street
abodyman  Offline
super street
Ok, I agree the brass plugs are better, but just wait till You need to take one of the "deep" plugs out. They are about 10 times harder to get out!
The stock ones just flip out when You use a punch on the edge of them.
Id rather use a brass short plug, if they are available anywhere.
Re: Freeze plugs leaking in 440 What's best to use? [Re: Pyper70] #187893
01/08/09 10:48 PM
01/08/09 10:48 PM
I have not seen those but they should last until overhaul time.
