Minimum Compression Heigth?? #187787
01/08/09 02:12 PM
01/08/09 02:12 PM
Alexandria, LA
Blucuda413 Offline OP
Alexandria, LA
What is the minimum CH in a smallblock which would keep the rings out of the pinhole???
Re: Minimum Compression Heigth?? [Re: Blucuda413] #187788
01/08/09 02:17 PM
01/08/09 02:17 PM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
The method Diamond uses, around 1.325" but, you can stack the rings tighter
and go with less. That's just their preference on the ring spacing.
Edit: That was using 1/16 x 1/16 x 3/16 ring pack.
Re: Minimum Compression Heigth?? [Re: S/ST 3040] #187789
01/08/09 02:20 PM
01/08/09 02:20 PM
Alexandria, LA
Alexandria, LA
My current configuration has a 1.21 with custom pistons. I'm looking at a combo which would only be a .975. Is this way too short????
Re: Minimum Compression Heigth?? [Re: Blucuda413] #187790
01/08/09 02:23 PM
01/08/09 02:23 PM
S/ST 3040 Offline
S/ST 3040  Offline
I'd say YES but, almost everybody has shelf pistons for SBC @ 1.00"
Re: Minimum Compression Heigth?? [Re: Blucuda413] #187791
01/08/09 02:23 PM
01/08/09 02:23 PM
Oklahoma
hemiiroc Offline
hemiiroc  Offline
Oklahoma
.975 is way short
Re: Minimum Compression Heigth?? [Re: hemiiroc] #187792
01/08/09 03:15 PM
01/08/09 03:15 PM
south central pa
bdaz smblk Offline
bdaz smblk  Offline
south central pa
I have a .975 comp. ht with my 4" stroke and a 9" deck block and I won't do it again when I build my next motor.
3120lb, small block, 10.5" tire, NA, through exhaust, full int, WITH 83/4 REAR, 9.0 at 150mph
Re: Minimum Compression Heigth?? [Re: bdaz smblk] #187793
01/08/09 03:47 PM
01/08/09 03:47 PM
France Europe
Laurent Offline
Laurent  Offline
France Europe
Why ? What's the trouble ?
Re: Minimum Compression Heigth?? [Re: Laurent] #187794
01/11/09 12:57 PM
01/11/09 12:57 PM
Alexandria, LA
Alexandria, LA
BTT, It looks like the answer is somewhere between .975 and 1.20. Any more inputs with experience and recommendatoons?????
Re: Minimum Compression Heigth?? [Re: Blucuda413] #187795
01/11/09 01:45 PM
01/11/09 01:45 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
Not small block but.
The last Custom Diamonds I purchased was at 1.32 which didn't need oil rail supports. The Current Wiseco's at 1.29 do need them. So somewere in between...
Re: Minimum Compression Heigth?? [Re: Blucuda413] #187796
01/11/09 02:26 PM
01/11/09 02:26 PM
Cab_Burge Online work
Cab_Burge  Online Work
It depends What size wristpin and type of rod has a lot to do where the pin hole can be put in the pistons, right
Re: Minimum Compression Heigth?? [Re: Cab_Burge] #187797
01/11/09 03:06 PM
01/11/09 03:06 PM
Alexandria, LA
Alexandria, LA
Cab, I didn't even think about the wrist pin size. My current combo with a 9.56 deck heigth, 3.91 stroke, 6.4 Alum rods and .927 pin provides me the 1.21 comp heigth. You're right a pin of less than .927 would provide some additional room.
I'm just looking for a safe number to plan for my next build. At this juncture it's easy to also vary the rod length. I was planning on a 6.5 rod which may not work.
Re: Minimum Compression Heigth?? [Re: Blucuda413] #187798
01/12/09 07:41 PM
01/12/09 07:41 PM
Orlando Fl
Dos Snails Offline
Dos Snails  Offline
Orlando Fl
I've had two different sets of dished JE's at 1.12 .One set had support rails for the oil rings & the other did not..
