valve tip wipe pattern check please
#1877872
07/25/15 02:40 PM
07/25/15 02:40 PM
Posts: 1,894 Spahn Ranch
RMCHRGR
Spahn Ranch
Does this wipe pattern look right? Looks too narrow IMO but I am not sure. At least it is centered. This is just the #1 intake valve, have not checked any other valves yet. The combo is a 340/416 using RHS LA heads. Cam is a solid F/T - .556" lift intake and .549" ex. with Hughes 1.6 rockers to yield .593" in. and .586" ex. Using Hughes rocker stuff - shafts, hold downs, etc. Heads are not fully torqued yet, just snugged down with head gaskets in place. Inner valve springs removed. No rocker stand shims. Adjustable pushrod measures approximately 7.5". I don't have a large enough caliper to measure accurately. Looks about right to me but again, just checking. Appears much longer than stock and shorter than my last 340/W2 combo which were exactly 8.00". Thanks for any input/suggestions.
'71 Duster '72 Challenger '17 Ram 1500
Re: valve tip wipe pattern check please
[Re: rickseeman]
#1877881
07/25/15 03:13 PM
07/25/15 03:13 PM
Posts: 20,197 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Some guys would kill to get a pattern like that but it should be in complete ready condition. I still think it will look great.
[Re: pittsburghracer]
#1877914
07/25/15 04:17 PM
07/25/15 04:17 PM
RMCHRGR
Spahn Ranch
Some guys would kill to get a pattern like that but it should be in complete ready condition. I still think it will look great. I was wondering about having everything tight and ready to run. Will I see a variance with everything tight and could it be adjusted if necessary? Want to order pushrods, just want to make sure I get the right length. Just thought of two more things I had questions about - I only had about a thread and half of the adjuster showing underneath the rocker. Is that enough or do I want more like 2-3 threads? #2 - should lash be factored in when checking the pattern? Thanks.
[Re: RMCHRGR]
#1877974
07/25/15 06:37 PM
07/25/15 06:37 PM
Posts: 1,267 North, Alabama
D-50
North, Alabama
I have some Manton push rods that has about 10 passes on them that are 7.60 and 7.64 length 11/32 x .120 wall if you can use them.They cost me $180.00 , I will take $100 plus shipping if you are interested. They have the ball on each end.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
[Re: D-50]
#1878294
07/26/15 09:20 AM
07/26/15 09:20 AM
RMCHRGR
Spahn Ranch
I have some Manton push rods that has about 10 passes on them that are 7.60 and 7.64 length 11/32 x .120 wall if you can use them.They cost me $180.00 , I will take $100 plus shipping if you are interested. They have the ball on each end. Thanks but I need ball/cup.
[Re: RMCHRGR]
#1878327
07/26/15 11:21 AM
07/26/15 11:21 AM
Posts: 4,210 New York
polyspheric
New York
Re: Looks too narrow
The perfect sweep would be a line with no thickness, but that needs the rocker to be 3 feet long. The ratio of gross lift (at the valve) to valve-side lever length controls maximum sweep, not geometry.
Boffin Emeritus
[Re: RMCHRGR]
#1878729
07/26/15 10:45 PM
07/26/15 10:45 PM
RMCHRGR
Spahn Ranch
Thanks for the replies. Never thought I would hear the word perfect associated with something I touched but sometimes you get lucky.
[Re: RMCHRGR]
#1878862
07/27/15 12:34 AM
07/27/15 12:34 AM
Posts: 12,592 Great Neck,LI,new york
hemi-itis
Thanks for the replies. Never thought I would hear the word perfect associated with something I touched but sometimes you get lucky. You underestimate your ability grasshopper
