Water cooling a 518
#1877470
07/24/15 07:52 PM
07/24/15 07:52 PM
Posts: 1,490 smyrna,tn
draginmopars
smyrna,tn
I ordered an auxiliary trans cooler, but found out it's on back order http://www.xtremediesel.com/BD-Power-1300601-Xtruded-Auxiliary-Trans-Cooler.aspxPlan "B" remembered I had a cooler from a cummins has the correct size fittings as the trans normal life it resides under the exhaust manifold and turbo also behind the oil cooler, doesn't get any fresh air trans lines- cut 2 holes and run the line inside the inner fender/ build a rock guard then into bulkhead connectors, along the frame/above the t-bar then in front of the trans cross member, turn up/forward into the trans case cooling line- normal line going from water pump housing to the factory in car heater out of heater and into back of trans cooler out of trans cooler into upper radiator tank Makes a circle/loop, trying to make a clean install no room to mount it on the driver's side, plus the water line would have to cross over the engine Do you think it will work??? or wait for the other cooler thanks
Ha-Ha Racin Havin Fun 101
Howard
68 "Cummins" Satellite 70 W-2 449 "More Door" Dart 70 340 Dart Swinger, 4spd 71 360 Dart Swinger 72 540/ 518 Dart Swinger 73 airwolf 446/a-500 Cuda 73 "Cummins" Crew cab-car hauler 84 446 Dodge Rampage (tube chassis) 92 CTD 11' flat bed 92 CTD club cab 07 Dodge Caliber
Re: Water cooling a 518
[Re: BDW]
#1877561
07/24/15 10:48 PM
07/24/15 10:48 PM
draginmopars
smyrna,tn
That's a lot of work, money and cooling. Why do you think it's needed?
I used the factory cooler from the van I pulled the 518.
95 Dodge 3600, go to RockAuto, $50. from a post back in feb since the topic is info about the overdrive unit 518,618 >> ect. Does anyone know if the valve bodys are the same (shift valves/ springs) Non lock up 518> (gas engine) and Non lock up 618 (Diesel) plan is use a JW bell on the 618 change the governor to shift at 4500 I mated a 618 to a JW bell to get the most clutches, 4 pinion planetary ETC. doing that the case has the larger fittings (1/2") a (gas) factory radiator has the smaller 3/8" fittings want the trans to run as cool as possible... right now I can barely run 170* on the engine>540> E-85 If I want to round robbin/ run it hard, I can. bucket list> Drag week, and one mile run.
Howard
[Re: ahy]
#1877565
07/24/15 10:57 PM
07/24/15 10:57 PM
draginmopars
smyrna,tn
You are tapping into the cooling system on the hot side with the heater connection. That hot water won't be effective cooling and may actually warm the fluid up.
I don't know how or where you would find a pressurized source of cool water pumped from the radiator bottom tank... you could somehow tap into the cool water feed from the pump into the block. Wouldn't be pretty and may throw the engine cooling system out of balance.
I think I'd wait for the other cooler (hopefully a good size unit to go in front of the radiator). thanks for the reply I'm not disputing what you say I'm trying to learn, this is why I'm asking can I put the radiator fitting in the bottom tank draw from it into the trans cooler out the back of the trans cooler go to the heater core from there go to the pipe fitting at the pump Isn't it low pressure? would draw water thru? Only reason to run thru the heater core is to make the trans cooler, a clean look Don't drive it in the winter/ don't need cabin heat Yes, it would heat the inlet water, but I also block the bypass hole in the housing (have for years, no thermostat, just a restriction ring as I said in the other post, I can barely get to 170* partly cause, I'm not sucking hot water thru the bypass hole, and running E-85.
Howard
[Re: draginmopars]
#1877583
07/24/15 11:29 PM
07/24/15 11:29 PM
draginmopars
smyrna,tn
once I get it running, while waiting on the other cooler
I may set a bucket of water on the floor and see if the pump can draw water from the pipe fitting ( for fun and to learn) LOL
Howard
[Re: draginmopars]
#1877734
07/25/15 10:10 AM
07/25/15 10:10 AM
Posts: 1,406 New Jersey, USA
yella71
New Jersey, USA
That will work fine. That's how it is plumbed on trucks with a diesel. All modern cars and trucks have multiple coolers (trans, p/s, engine oil, etc) that runs the engine coolant thru them to bring all the fluids to the same temp (the eng temp). Also to bring all the fluids up to temp faster. If you use the heater exit line that is not the "hot" side it is the cool side. The water pump does not pull fluid it pushes coolant thru the motor. It will not disrupt the cooling system, you'll just add some capacity.
71 challenger convertable, 64 sport fury 383 ci with factory air
99 sebring convertable
89 CTD pup
[Re: yella71]
#1877745
07/25/15 10:40 AM
07/25/15 10:40 AM
draginmopars
smyrna,tn
The water pump does not pull fluid it pushes coolant thru the motor. It will not disrupt the cooling system, you'll just add some capacity. that's what I based the idea on>>> Was looking at how it was set up on the cummins engine, I have here. understand the pump pushes... the area with the pipe fitting, is located BEHIND the impeller, (same as the inlet hose) Wouldn't it be lower pressure? than at the outlet> upper hose thanks
Howard
