What heat range plugs in warmed small block?
#187749
01/08/09 01:22 PM
01/08/09 01:22 PM
Posts: 401 Berlin, Germany
Flo
Berlin, Germany
HI, what heat range do you guys run in your LA-motors? Stock for mine would be a Bosch number 10 which is a super hot plug. I am a little worried that this would cause detonation... I am considering to use a Bosch 6 or 7 now, which is NGK 6 or Champion 9 or 10. What we are talking about if you want to read it all: Quote:
-late 318 LA-block (factory roller lifters) bored .040 over (after sonic check) mild stroker crank 3.51 stroke -some dished pistons @,010 deck height. comes out to 344cui, 9.5 compression with the heads mentioned below.
302 heads with 2,02 in and 1,8 exh valves (3 angle valve job with back cut... pocket porting... gasket matched to intake)
Edelbrock Performer intake Edelbrock Performer 600 carb
Comp CAM 264HR-12 DUR @.050: 210 220 MAX GROSS VALVE LIFT .480 .480 DUR @ .006 TAPPET LIFT 264 274 LOBE SEPARATI 112.0 installed straight (As far as I understood they grind them advanced).
roller rockers with 1.6 ratio (cam specs are with 1.5 ratio)
Hooker comp headers
dual exhaust 2,25"
Greets Flo
1967 Fury III 4door HT
tiny 318, late model roller block, bored and stroked to 344
Re: What heat range plugs in warmed small block?
[Re: Flo]
#187751
01/08/09 01:50 PM
01/08/09 01:50 PM
Posts: 5,444 Indiana
YO7_A66
Indiana
I started with the NGK 4's, then the 5's, then the 6's, and I have been running the cooler 7's for over a year now. The cooler 7's helped with detonation and they allow me to run on 89 octane (9.7:1) and my plugs are clean with the FBO ignition.
1970 YO7 A66 [Canadian Export] F8 Challenger 340 (Currently in shop for stroker assy.)
[Re: Flo]
#187753
01/08/09 03:36 PM
01/08/09 03:36 PM
RapidRobert
With you using bosch's I would start with a bosch that crosses over to a champion 12. A Champion 9 equivelent would for sure be too cold & your CR isn't very high & you didn't say street or strip but I would start at 12 & see if you can access the thread that might be in the archives that had EXCELLENT plug reading pics(heat range & mixture)
[Re: RapidRobert]
#187754
01/09/09 05:29 AM
01/09/09 05:29 AM
Flo
Berlin, Germany
Ok, as recomendations are all over the place and plugs are cheap I will start with a Bosch number 7 and see if they foul... Greets Flo
[Re: Dragula]
#187757
01/09/09 04:39 PM
01/09/09 04:39 PM
Posts: 3,902 Oregon
hooziewhatsit
I finally found the article about reading plugs I saw quite a while ago. http://www.dragstuff.com/techarticles/how-to-read-plugs.htmlIn my mildly built 318, with Champion RN14YCs, there is color on the ground strap all the way to the base ring. So the above article would indicate mine could go one step colder? -Dave
[Re: hooziewhatsit]
#187758
01/09/09 04:45 PM
01/09/09 04:45 PM
RapidRobert
that's it, a comprehensive a plug article as you could ask for. With an innovate LM-1 A/F ratio meter with an rpm converter a person is all set to get your mixture dead on & wring out every last bit of horsepower that can be had.
