Black MP valve covers? Hard to seal? #1876090
07/22/15 09:38 PM
07/22/15 09:38 PM
Monee IL
chicagotim2003 Offline OP
Monee IL
I`m thinking about getting some mopar performance valve covers. 440 the black cast kind. Are these leak prone? I have a edelbrock manifold and headers. What kind of gaskets does everyone use? Any other tips to pass on? As always thanks for the replies.
Re: Black MP valve covers? Hard to seal? [Re: chicagotim2003] #1876101
07/22/15 09:56 PM
07/22/15 09:56 PM
South San Francisco, Ca
70sixpkrt Offline
70sixpkrt  Offline
I switched from my chrome valve covers to the MP Polished cast aluminum valve covers and used the felpro 1612 high temp gaskets. I used Felpro Right Stuff to glue them to the valve cover ( not the heads) and so far no leaks. I also used the bolts instead of studs on my covers.
http://www.summitracing.com/parts/fel-1612
[img]http://www.imgur.com/hxlGUJt.gif[/img]
4-speed
3:54 Dana
13.01 @107.93 with street tires (not hooking up)
Re: Black MP valve covers? Hard to seal? [Re: chicagotim2003] #1876102
07/22/15 09:56 PM
07/22/15 09:56 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
Moroso is what works for me
link
gaskets link
Re: Black MP valve covers? Hard to seal? [Re: chicagotim2003] #1876121
07/22/15 10:21 PM
07/22/15 10:21 PM
Canada
CTD5.9 Offline
CTD5.9  Offline
Canada
Follow the proper tightening instructions, I cracked the corner of mine being dumb earlier this year. I used superformance gaskets with mine
Re: Black MP valve covers? Hard to seal? [Re: CTD5.9] #1876229
07/22/15 11:59 PM
07/22/15 11:59 PM
IN
ahy Offline
ahy  Offline
IN
I find they are pretty stiff and relatively easy to seal... why I like them.
Re: Black MP valve covers? Hard to seal? [Re: chicagotim2003] #1876429
07/23/15 08:30 AM
07/23/15 08:30 AM
New Jersey, USA
Y
yella71 Offline
yella71  Offline
Y
New Jersey, USA
the issue I had with mine on a small block was they hit the intake manifold at the runners. so I trimed them with a grinder. mopar factory heads at the valve cover surface are some of the worst heads I've ever seen. get a good thick gasket and tighten them even and they will seal great. Mine came with bolts and gaskets but If I remember the bolts were too short. either way If you put them on right they are good.
71 challenger convertable, 64 sport fury 383 ci with factory air 99 sebring convertable 89 CTD pup
Re: Black MP valve covers? Hard to seal? [Re: chicagotim2003] #1876546
07/23/15 01:16 PM
07/23/15 01:16 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
73EStroker
Loc: Calgary, AB, Canada
"These were the only working solution for my Indy EZ and crappy MP valve covers. Now the back of the engine is clean. It was the valve covers. The heads have perfect machined surfaces. So did the valve covers but they don't seem to have the same layout pattern as everything else and were barely sealing in places. I did have to retorque though."
https://board.moparts.org/ubbthreads/ubbt...tml#Post1503062
Re: Black MP valve covers? Hard to seal? [Re: chicagotim2003] #1876602
07/23/15 03:26 PM
07/23/15 03:26 PM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
I've had 'as cast' covers over a 440 with high-temp gaskets(dry) for many years...
They leak not a drop...
Re: Black MP valve covers? Hard to seal? [Re: yella71] #1877167
07/24/15 12:02 PM
07/24/15 12:02 PM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
These are the two most common issues I've seen with getting a good seal. Test fit them without gaskets to see how low and flat they fit. If you have any gaps greater than a gasket's thickness, you need to address that issue before bolting them down.
