Re: Black MP valve covers? Hard to seal?
[Re: chicagotim2003]
#1876102
07/22/15 09:56 PM
07/22/15 09:56 PM
Posts: 2,871 Pattison Texas
CSK
Pattison Texas
Moroso is what works for me link gaskets link
#1876429
07/23/15 08:30 AM
07/23/15 08:30 AM
Posts: 1,406 New Jersey, USA
yella71
New Jersey, USA
the issue I had with mine on a small block was they hit the intake manifold at the runners. so I trimed them with a grinder. mopar factory heads at the valve cover surface are some of the worst heads I've ever seen. get a good thick gasket and tighten them even and they will seal great. Mine came with bolts and gaskets but If I remember the bolts were too short. either way If you put them on right they are good.
71 challenger convertable, 64 sport fury 383 ci with factory air
99 sebring convertable
89 CTD pup
#1876546
07/23/15 01:16 PM
07/23/15 01:16 PM
Posts: 3,675 Akron, Ohio U.S.A.
roadhazard
Akron, Ohio U.S.A.
73EStroker member Registered: 03/29/13 Posts: 12 Loc: Calgary, AB, Canada "These were the only working solution for my Indy EZ and crappy MP valve covers. Now the back of the engine is clean. It was the valve covers. The heads have perfect machined surfaces. So did the valve covers but they don't seem to have the same layout pattern as everything else and were barely sealing in places. I did have to retorque though." https://board.moparts.org/ubbthreads/ubbt...tml#Post1503062
[Re: yella71]
#1877167
07/24/15 12:02 PM
07/24/15 12:02 PM
Posts: 5,394 Pikes Peak Country
TC@HP2
Pikes Peak Country
the issue I had with mine on a small block was they hit the intake manifold at the runners. so I trimed them with a grinder. mopar factory heads at the valve cover surface are some of the worst heads I've ever seen. get a good thick gasket and tighten them even and they will seal great. These are the two most common issues I've seen with getting a good seal. Test fit them without gaskets to see how low and flat they fit. If you have any gaps greater than a gasket's thickness, you need to address that issue before bolting them down.
