Dodge Ram Magnum 5.9 exhaust manifolds fit a F-body? #1877152
07/24/15 11:30 AM
07/24/15 11:30 AM
Eastern Ohio
mopowergtx Offline OP
Eastern Ohio
Will the Ram exhaust manifolds off the 5.2 and 5.9 Magnum motors fit in the older body styles of cars, A, B, F, M, J? Seen a set of the bigger ones the 92/93 I believe they are for $50 wonder if theyd be worth picking up for a project down the road. They sure exit far to the rear.
Re: Dodge Ram Magnum 5.9 exhaust manifolds fit a F-body? [Re: mopowergtx] #1877165
07/24/15 12:00 PM
07/24/15 12:00 PM
Andrewh Offline
Andrewh  Offline
I have a set from a 2000 durango in an early b. they fit pretty well. clears power steering.
Re: Dodge Ram Magnum 5.9 exhaust manifolds fit a F-body? [Re: mopowergtx] #1877677
07/25/15 02:33 AM
07/25/15 02:33 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
The RH/Passenger side is a great design and accomplishes 2 things: It flows better than even the 340 manifold AND it only requires one bend in the exhaust pipe approx 45 degrees. The standard straight down exit style usually has 2 bends to clear the steering. The truck manifold dumps just over the oil filter.
The LH/Driver side is a tough one. The reason it might clear in an early b body is because those cars had the engine mounted a bit further forward than the later B and other models. The exit port on the left manifold is really close to the firewall on a 67-76 A body, not sure of the fitment on other cars. If you have a 4 speed, the clutch torque shaft is in the way. Of you have a column automatic, the trans shifter linkage is in the way.
