Re: 73 challenger dies in gear??
[Re: chicagotim2003]
#1877023
07/24/15 01:26 AM
07/24/15 01:26 AM
RapidRobert
ported or manifold? what idle speed? what initial? recent problem? what carb? I'd take out the two idle mixture screws and shoot a 3 second blast of starting fluid into each port then replace the screws. slightly ream out the plastic nozzle on a can of starting fluid so you can affix one of those thin red straws to it to get the straw into the carb idle mixture ports for a good blast. On the slo cranking you always wanna start with the battery & subbing in a borrowed one will ans that real quick. might be dirty cables/terminals or ground path also or heat soak in the starter. far less likely is eng drag & I'm assuming not from too small of cables in a trunk batt app. holler back EDIT if you have 13.5 it ain't being undercharged. To pursue that further you might need a better meter or scare up an analog meter to borrow
#1877670
07/25/15 02:09 AM
07/25/15 02:09 AM
RapidRobert
Update. Dropped it into d and r. Rpms went down but car did not die. I feel i`m missing something.?? whats my next move? It ain't dieing now? More info please
#1879204
07/27/15 03:40 PM
07/27/15 03:40 PM
Posts: 5,444 Indiana
YO7_A66
Indiana
""Timing is slightly advanced""
What is your timing?
1970 YO7 A66 [Canadian Export] F8 Challenger 340 (Currently in shop for stroker assy.)
