Need a little help with 440 bearings #1876871
07/23/15 09:53 PM
07/23/15 09:53 PM
Mt.Vernon ,Ohio
VernMotor Offline OP
Mt.Vernon ,Ohio
I have a eagle crank so we need narrow rod bearing .I had to have the crank turn down to .020. I can't seem to come up with the right part number. What is everyone using ? I want 3/4 to full groove mains.
Re: Need a little help with 440 bearings [Re: VernMotor] #1876919
07/23/15 10:44 PM
07/23/15 10:44 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Check these out to see if its what you are looking for.
http://store.440source.com/Rod-Bearings/products/111/
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Need a little help with 440 bearings [Re: VernMotor] #1876923
07/23/15 10:49 PM
07/23/15 10:49 PM
Mt.Vernon ,Ohio
Mt.Vernon ,Ohio
LOL I like how they are saying rod bearing and showing pics of main bearing. Anyhow I don't see .020 under there.
Re: Need a little help with 440 bearings [Re: VernMotor] #1877000
07/24/15 12:46 AM
07/24/15 12:46 AM
Aurora, Oh.
max_maniac Offline
max_maniac  Offline
Aurora, Oh.
Vern!!!!!! Where have you been????
At least you still have the car..........
Re: Need a little help with 440 bearings [Re: VernMotor] #1877446
07/24/15 07:22 PM
07/24/15 07:22 PM
Mt.Vernon ,Ohio
Mt.Vernon ,Ohio
Well I am trying to get this motor done....need bearing Dang gone it !!
Re: Need a little help with 440 bearings [Re: VernMotor] #1877471
07/24/15 07:54 PM
07/24/15 07:54 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Just to be clear, you need .020" undersize rod & main bearings for an RB crank w/ radius fillets, right?
EDIT: Nope, don't see any that'll cut it OOB. I suspect you may need to resort to using standard Clevite 77 or Sealed Power CP-series .020" rod bearings & .020" full-groove main bearings, some fixtures like these HERE, and finding someone w/ a lathe to narrow them, assuming you don't have a lathe yourself.
Re: Need a little help with 440 bearings [Re: VernMotor] #1877647
07/25/15 01:44 AM
07/25/15 01:44 AM
reynoldsburg,ohio
poppaj Offline
poppaj  Offline
reynoldsburg,ohio
You can chamfer them yourself, small half round file, it don't take much to clear chamfer
AA/NSS 65'Coronet "Whompin Wedge"
Pop & Son Performance 557" B-1 power
John Holt Chassis
Re: Need a little help with 440 bearings [Re: BradH] #1877886
07/25/15 03:22 PM
07/25/15 03:22 PM
Mt.Vernon ,Ohio
Mt.Vernon ,Ohio
OK thank you ..this what I needed to know..
