cam for 408 in a 89 Dodge 3/4 ton 4X4 #1876060
07/22/15 08:23 PM
07/22/15 08:23 PM
Ia
4spdana Offline OP
4spdana  Offline OP
Ia
408 short block will be 9to1 with 63cc 915 smog heads with 2.02 /1.60,hard seats , bowl work.
performer intake,
need a carb , was thinking a 650 holley vacuum secondary , want to build torque, heavy truck.
headers....1-5/8
i like the comp cam extreme stuff, takes advantage of the .904 lifter, which cam do you think i should use?
using stock rockers , thinking 5800 - 6000
Re: cam for 408 in a 89 Dodge 3/4 ton 4X4 [Re: 4spdana] #1876088
07/22/15 09:31 PM
07/22/15 09:31 PM
Ia
4spdana Offline OP
4spdana  Offline OP
Ia
this truck has 4.10 with 37 inch tires
Re: cam for 408 in a 89 Dodge 3/4 ton 4X4 [Re: 4spdana] #1876135
07/22/15 10:40 PM
07/22/15 10:40 PM
Spahn Ranch
RMCHRGR Offline
RMCHRGR  Offline
Spahn Ranch
In a 3/4 ton 4x4 with 37" tires?
'71 Duster
'72 Challenger
'17 Ram 1500
Re: cam for 408 in a 89 Dodge 3/4 ton 4X4 [Re: RMCHRGR] #1879218
07/27/15 03:53 PM
07/27/15 03:53 PM
dogdays Offline
dogdays  Offline
Only the Comp XE...HL line is speced for the 0.904 lifter. I believe all Lunati Voodoo cams are. Hughes is where I'd go, They'd make a good choice.
R.
