I have a high miles 98Ram 2wd (278k miles), the brake line to the rear rotted through behind the fuel tank, so I replaced ALL the hard lines from mid cab rearward to the cyls and also replaced the cyls as well since they were the originals and new brakes as well. Moving up to the front, replaced the cals cuz one side was grabbing, yes, they were original as well, new hoses and pads and completely refilled the system with new fluid. For a long while BEFORE the brake line rotted through, it just didn't stop very well, felt like it had a decent pedal, but a panic stop was just out of the question, safe for normal driving, but I wouldn't have wanted to depend on a sudden need to stop. Now, after all this, it feels as though its got a good, firm pedal and it stops straight now, but it still doesn't stop very well, I mean if I needed to stop quick, and I'm not sure why. Bled and rebled the brakes, but still not real good. My question is this, the truck also retains the OE booster, could this be whats keeping it from stopping well, and if so, how would I check that? Or maybe the master cyl, which is also OE? Thanks.
