Re: 727 TF question
[Re: Steve88]
#1875930
07/22/15 05:57 PM
07/22/15 05:57 PM
Posts: 25,794 Rio Linda, CA
John_Kunkel
Rio Linda, CA
The whine is often caused by a rapidly cycling pressure regulator in the trans. More of a nuisance than a real problem. Factory recommended replacing the valve body.
Could also be a leaking rear servo piston seal.
Re: 727 TF question
[Re: John_Kunkel]
#1876446
07/23/15 10:10 AM
07/23/15 10:10 AM
Posts: 129 Springfield, MO
Steve88
Springfield, MO
Could also be a leaking rear servo piston seal. Thank you for the info, I was hoping to hear an answer like!
Re: 727 TF question
[Re: Steve88]
#1877087
07/24/15 05:52 AM
07/24/15 05:52 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
I rememeber some Dodges doing it that came in the dealer I worked at. I believe on some you could replace the aluminum spool valve with a steel one to help some. But as John said was more a nuisance then anything as it did not cause a real problem. Ron
