Spray undercoating #1875047
07/21/15 01:39 PM
07/21/15 01:39 PM
robertop Offline OP
robertop  Offline OP
I am redoing the undercoating in my 69 Roadrunner. I bought a gallon of Rick's stuff, but now I cannot use what I had to spray it. I am left with the fuel lines at the tank and part of the gas tank and it would be nice to use some spray bomb to finish my work. Is there a product I can buy at a part store that would be good enough? Nobody will probably notice if it's not perfect, and it was not perfect in the first place anyway. Thank you, guys.
Re: Spray undercoating [Re: robertop] #1876963
07/23/15 11:49 PM
07/23/15 11:49 PM
ar
reborn73 Offline
reborn73  Offline
ar
I used the same stuff from Rick for some touch up. I used several different types of sponges to dab the undercoating on. Practice on a piece of cardboard until you get the right texture. You can't tell the old from the new on mine now
